Pascal Scripting with Inno Setup
Message 1 of 9
In INNO setup I'd like to abort setup if AutoCAD is running. I would like to
use the function "FindWindowByWindowName(const WindowName: String):
Longint;" to determine whether AutoCAD is running in the InitializeSetup()
function. Does anyone know what window name to use for AutoCAD? Theres also
a FindWindowByClassName(const ClassName: String): Longint;" function if
anyone knows the class name.
Does anyone have any better suggestions?
D.M. Levesque
Replies (8)
Message 2 of 9
You don't have to go to that extents, not
to mention that it doesn't work reliably
since you can't count on exactly what the
AutoCAD window's caption might be.
You just need this:
uses
ComObj, ActiveX;
Function IsAutoCADRunning: Boolean;
begin
Result := True;
try
GetActiveOleObject('AutoCAD.Application');
except
Result := False;
end;
end;
http://www.acadxtabs.com
"Dale Levesque" wrote in message
news:B945D90D59C4344DDE818851539DEB13@in.WebX.maYIadrTaRb...
> Thanks,
> D.M. Levesque
Message 3 of 9
On Fri, 22 Aug 2003 15:50:56 -0700, "Dale Levesque"
>Thanks,
>D.M. Levesque
You might want to try WinDowse from http://www.greatis.com/. It will
tell you the window name & class name of a running app, which you
should then be able to use in your code.
Ray Greene.
Message 4 of 9
You just need this:
uses
ComObj, ActiveX;
begin
Result := True;
try
except
Result := False;
end;
end;
> Thanks,
> D.M. Levesque
Message 5 of 9
Thanks!
"Tony Tanzillo" wrote in message
news:9D8AE4534168A0240A8C0538F326608C@in.WebX.maYIadrTaRb...
> You just need this:
> uses
> ComObj, ActiveX;
> begin
> Result := True;
> try
> except
> Result := False;
> end;
> end;
like to
InitializeSetup()
also
> > Thanks,
> > D.M. Levesque
Message 6 of 9
Thanks again Tony but one question. I'm very new to Pascal scripting and I'm
unsure as to how to indicate that the function requires ComObj and ActiveX.
I tried pasting:
uses
ComObj, ActiveX;
just above the function but that didn't work.
Best regards,
Dale
news:ECAF9CC8F8960FC74C6D3BB713523EDE@in.WebX.maYIadrTaRb...
> You just need this:
> uses
> ComObj, ActiveX;
> begin
> Result := True;
> try
> except
> Result := False;
> end;
> end;
like to
InitializeSetup()
also
> > Thanks,
> > D.M. Levesque
Message 7 of 9
Hi Tony,
Apparently Inno Setup does not allow the use of "uses" in it's [CODE]
section. Thanks anyway for the help.
Dale
> You just need this:
> uses
> ComObj, ActiveX;
> begin
> Result := True;
> try
> except
> Result := False;
> end;
> end;
like to
InitializeSetup()
also
> > Thanks,
> > D.M. Levesque
Message 8 of 9
Thanks Ray. That app seems to work fine but it's resulting class name
doesn't seem to work as far as my code goes.
Dale
"Ray Greene" wrote in message
news:6ohdkvgjeslumku3jogbbrgie8jdc90cs4@4ax.com...
to
InitializeSetup()
also
> >Thanks,
> >D.M. Levesque
> Ray Greene.
Message 9 of 9
The Pascal script that's being used in Inno Setup 4 (which is
what I assume you're using) doesn't support ActiveX or 'uses",
so what I showed isn't going to work. I didn't even know that
version 4 had it, but it's still beta anyway.
news:5F6887F4F56BE15095D9AC7701ABEAB7@in.WebX.maYIadrTaRb...
> Hi Tony,
> Dale
> > You just need this:
> > uses
> > ComObj, ActiveX;
> > begin
> > Result := True;
> > try
> > except
> > Result := False;
> > end;
> > end;
> like to
> InitializeSetup()
> also
> > > Thanks,
> > > D.M. Levesque
