Partition Function
Partition Function
Partition Function
When using the Partition function, where are the resulting values stored, and how do you access those values?
TIA
Albert
jbooth
The partition function of which object/class/module?
No, I don't believe that's the same thing. I mean the partition function, as in: Partition (number, start, stop, interval).
jbooth
So you want the Partition function of the Visual Basic IDE (MSVBVM60.DLL).
http://msdn2.microsoft.com/en-us/library/ek4702k8(VS.80).aspx
Example (copied from the link):
dim result as string
result = Partition(year, 1950, 2049, 10)
'result will now be: "1980:1989"
