OptionButton - Unable to set names properly within Frame
I am getting an error when I try to set multiple OptionButton names to the same name (within a frame) on a UserForm. The message I get is "Could not set the name property. Ambiguous Name."
I want to be able to use this as a Control Array, so the OptionButton names within the frame should have the same name......is this not correct.
I would appreciate any help here....thanks
John V.
Ed__Jobe
vba does not support control arrays. I have worked around that in the past by using incremental alphanumeric names, i.e Control001, Control002, etc. I then examined the number portion of the name. I used this technique to create a number of textboxes at runtime according to the number of text items in the selection set.
Ed
How to post your code.
Thanks for the info.
Taking your example, I've been able to do the work around using an IF statement within the click-event of the OptionButton. Each button would need the IF.
You still need to keep the OptionButtons within a frame to treat them as a group. It works so far, so I'll keep it.
ie:
If optBtn1.Value = "True" Then
....code.....
thx.
JV
John,
I emulate a control array in VBA forms by using the frame's
Tag:
Private Sub optFull_Click()
  fraSF.Tag = 1#
End
Sub
Private Sub optHalf_Click()
  fraSF.Tag = 2#
End
Sub
Private Sub optEighth_Click()
  fraSF.Tag = 96#
End
Sub
HTH
R.
Robert Bell, MCSE
www.AcadX.com
for the info.
would need the IF.
ie:
        ....code.....
thx.
JV
