Option Button Validate
In a dialog I have 4 option buttons that when changed show stored values in a number
of different controls. If the user changes a value in one of the other controls and then
tries to change option buttons without hitting apply, I want to prompt them with a
messagebox.
Maybe some of the problems I am having are because this is in a addin dll ?? but if I
use a normal option button the validate sub fires but the click event never does. (just
like it works if you are stepping through code using the validate sub). If I change the
option buttons to graphical buttons then it works every time except the first.
The form loads, I edit a textbox which sets a Boolean to notify the validate that
something has changed, but then when I click a different option button the text change
event fires again??, and the validate doesn't. After that first time it works right.
Is there a better way to do what I want. If I put the code in the Mouse down event for
the option buttons is there any way to cancel the click event for it?
I imagine I could do it in the click event but it would take all kinds of Booleans and
checks and storing the old button name etc.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
Kent,
Will it work if you use the option button change event to set a form level
'changed' boolean flag? Then just check this flag in the same event and call
a prompt function...
Kevin
"Kent Keller" wrote in message
news:E0E99542CD1D331491C93EDD7B4453EB@in.WebX.maYIadrTaRb...
values in a number
controls and then
them with a
> messagebox.
dll ?? but if I
never does. (just
If I change the
first.
validate that
text change
works right.
down event for
Booleans and
> Kent
> Assistant Moderator
Hi Kevin
It will/would work, but it would take more effort. 8^) I would like to give them the
option with a yes/no/cancel messagebox to either apply and change, or not apply and change
or cancel the change. If the click event has fired I would have to have the name of the
previous button stored, and have a Boolean or something in a routine to be able to return
to it without refiring its click event code. I already have a Boolean to check if it is a
form load click event and one to check if anything actually changed or not(to know if I
need to fire the message box or not) so it starts getting a little messy.
It probably is the best way out, but I was really hoping there was a way to do it before
the change is made, and that is what the Validate event appears to be for. Unfortunately
it is one of those hard to debug things where the click never happens if you step through
it with F8, but does in normal run mode.
Kent
Assistant Moderator
"Kevin Terry" wrote in message
news:B1A2214335680A79C551FC7E38EBD451@in.WebX.maYIadrTaRb...
> Kent,
> Kevin
Kent
I see what you mean - for debugging such things I've sometimes put a 'stop'
statement in the code after such a section, then F5 to 'run' through just
that part and the code will break at the stop for you to continue stepping
through. Not sure if that will help this scenario though - it may be the
same behavior (read 'bug') will be evident that way as well. I've got an app
kind of like this that I never did fully debug - it works ok, but since it's
not really 'critical' I just left it in it's existing (half-a$$ed) state 😉
Sorry I can't help more...
Kevin
news:0205339B5A613DFE183DC7FDB4941EDB@in.WebX.maYIadrTaRb...
> Hi Kevin
give them the
apply and change
the name of the
able to return
check if it is a
not(to know if I
to do it before
Unfortunately
you step through
> Kent
> Assistant Moderator
> > Kent,
level
call
> > Kevin
