Openning a . pdf document
Can any one explain me hoe to open a pdf document by just click of a commnd button.
Igot a pdf document name "C:w.pdf" i want to open by the click a commnd button, i have Adobe Reader 6 installed in system.
Plese help.
Hi Benny!
Use the SHELL command of autocad (defined in acad.pgp)
Test it in commandline first:
sh c:\myFolder\myDocument.pdf
That's all - You can use SENDCOMMAND for the line above
Greetings from Bernie from austria
wrote in message news:5076425@discussion.autodesk.com...
button.
Plese help.
Hi Bernie,
Thnks for the reply the shell commnad you sent is not working moreover i need code for command button click event,plese help.
Thanks in advance.
Hi Benny!
You can also use the SHELL Command of VB
private sub commandbutton .......
shell "C:\programs\adobe\........\acrord32.exe c:\myFile.pdf" '
..... use the folders where you have Acrobat Reader installed
end sub
I have tested this on my system - it is rumming!
Greetings from bernie from austria
wrote in message news:5076475@discussion.autodesk.com...
Hi Bernie,
Thanks in advance.
Hi Bernie, I am verry happy to recieve your reply,your code is working, i am very thankfull to you.
Bye
benny said the following on 2/3/2006 1:11 AM:
> Hi,
> Plese help.
See:
http://rkmcswain.blogspot.com/2005/11/launch-pdf-from-autocad.html
R.K. McSwain
