this method uses the API. drop the following code into its own code module. The code module has routines for botyh File Open, and File save, dialog boxes....
'--- snip----------- snip----------- snip----------- snip----------- snip--------
Option Explicit
Public Declare Function CopyFile Lib "kernel32" Alias "CopyFileA" (ByVal lpExistingFileName As String, ByVal lpNewFileName As String, ByVal bFailIfExists As Long) As Long
'Public Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Public Const OFN_ALLOWMULTISELECT = &H200
Public Const OFN_CREATEPROMPT = &H2000
Public Const OFN_ENABLEHOOK = &H20
Public Const OFN_ENABLETEMPLATE = &H40
Public Const OFN_ENABLETEMPLATEHANDLE = &H80
Public Const OFN_EXPLORER = &H80000
Public Const OFN_EXTENSIONDIFFERENT = &H400
Public Const OFN_FILEMUSTEXIST = &H1000
Public Const OFN_HIDEREADONLY = &H4
Public Const OFN_LONGNAMES = &H200000
Public Const OFN_NOCHANGEDIR = &H8
Public Const OFN_NODEREFERENCELINKS = &H100000
Public Const OFN_NOLONGNAMES = &H40000
Public Const OFN_NONETWORKBUTTON = &H20000
Public Const OFN_NOREADONLYRETURN = &H8000
Public Const OFN_NOTESTFILECREATE = &H10000
Public Const OFN_NOVALIDATE = &H100
Public Const OFN_OVERWRITEPROMPT = &H2
Public Const OFN_PATHMUSTEXIST = &H800
Public Const OFN_READONLY = &H1
Public Const OFN_SHAREAWARE = &H4000
Public Const OFN_SHAREFALLTHROUGH = 2
Public Const OFN_SHAREWARN = 0
Public Const OFN_SHARENOWARN = 1
Public Const OFN_SHOWHELP = &H10
Public Const OFS_MAXPATHNAME = 128
Public Const OFS_FILE_OPEN_FLAGS = OFN_EXPLORER Or OFN_LONGNAMES Or OFN_CREATEPROMPT Or OFN_NODEREFERENCELINKS
Public Const OFS_FILE_SAVE_FLAGS = OFN_EXPLORER Or OFN_LONGNAMES Or OFN_OVERWRITEPROMPT Or OFN_HIDEREADONLY
Public Const OFS_MULTIFILE_OPEN_FLAGS = OFN_ALLOWMULTISELECT Or OFN_EXPLORER Or OFN_LONGNAMES Or OFN_CREATEPROMPT Or OFN_NODEREFERENCELINKS
Public Type OPENFILENAME
nStructSize As Long
hwndOwner As Long
hInstance As Long
sFilter As String
sCustomFilter As String
nCustFilterSize As Long
nFilterIndex As Long
sFile As String
nFileSize As Long
sFileTitle As String
nTitleSize As Long
sInitDir As String
sDlgTitle As String
flags As Long
nFileOffset As Integer
nFileExt As Integer
sDefFileExt As String
nCustDataSize As Long
fnHook As Long
sTemplateName As String
End Type
Public Llama As OPENFILENAME
Public Declare Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Long
Public Declare Function CommDlgExtendedError Lib "comdlg32.dll" () As Long
Public Declare Function GetShortPathName Lib "kernel32" Alias "GetShortPathNameA" (ByVal lpszLongPath As String, ByVal lpszShortPath As String, ByVal cchBuffer As Long) As Long
Public Declare Function GetSaveFileName Lib "comdlg32.dll" Alias "GetSaveFileNameA" (pOpenfilename As OPENFILENAME) As Long
Public MyHwnd As Long ' hwnd of MY app
' | -= Main sub to call File SAVE Dialog =- |
' | Parameters: FileName$ is a variable that the name of the SAVED |
' | file name is returned in. You do NOT have to pass |
' | a filename to this routine, one is returned. Note |
' | that the Win API checks for, and prompts, if the |
' | filename already exists. |
' | FileExt$ is the file extension name you wish the |
' | Dialog box to use, for default extension, file |
' | listings, and availablity innthe drop-down "file |
' | type" box. |
' | FileDesc$ is a descriptive name for the File Name |
' | Extension, used to describe the filetype in the drop |
' | down type box. |
' | DlgTitle$ is the name of the caption on the Dialog |
Public Sub SaveFile(hwnd As Long, Filename$, FileExt$, FileDesc$, DlgTitle$)
Dim lngGo As Long
Dim lngHwnd As Long
Dim strCurName As String
Dim strNewName As String
On Error GoTo Err_Control
strCurName = Filename$
lngHwnd = hwnd
Filename$ = vbdShowSave(lngHwnd, strCurName, FileExt$, FileDesc$, DlgTitle$)
Exit Sub
Err_Control:
'Just get out, to many things to account for
MsgBox Err.Description, vbCritical, "Too many errors, aborting"
End Sub
' | -= Main sub to call File OPEN Dialog =- |
' | a filename to this routine, one is returned. |
' | type" box. |
Public Sub FileOpen(hwnd As Long, Filename$, FileExt$, FileDesc$, DlgTitle$)
Dim lngGo As Long
Dim lngHwnd As Long
lngHwnd = hwnd
strNewName = vbdShowOpen(lngHwnd, strCurName, FileExt$, FileDesc$, DlgTitle$)
Filename$ = strNewName
Exit Sub
Err_Control:
End Sub
' | Interface from the "OpenFile" routine to the Windows API |
Public Function vbdShowOpen(lngHwnd As Long, strDwgName As String, FileExt$, FileDesc$, DlgTitle$) As Variant
Dim lngReturn As Long, ShortSize As Long
Dim LongName As String, shortName As String, strFill As String
Dim strDblSpace As String, strFilter As String
strFill = Chr(0): strDblSpace = strFill & strFill
Llama.nStructSize = Len(Llama)
Llama.hwndOwner = lngHwnd
'This section is for the filter drop down list
strFilter = FileDesc$ & strFill & FileExt$ & strFill
strFilter = strFilter & "All Files" & strFill & "*.*" & strDblSpace
Llama.sFilter = strFilter
'This is the default information for the dialog
Llama.sFile = strDwgName & Space$(1024) & strFill
Llama.nFileSize = Len(Llama.sFile)
Llama.sDefFileExt = FileExt$
Llama.sFileTitle = Space(512)
Llama.nTitleSize = Len(Llama.sFileTitle)
Llama.sInitDir = CurDir
Llama.sDlgTitle = DlgTitle$
' use below to call open dialog
Llama.flags = OFS_FILE_OPEN_FLAGS
lngReturn = GetOpenFileName(Llama)
If lngReturn Then
vbdShowOpen = Llama.sFile
End Function
' | Interface from the "SaveFile" routine to the Windows API |
Public Function vbdShowSave(lngHwnd As Long, strDwgName As String, FileExt$, FileDesc$, Caption$) As String
Dim strFill As String, strDblSpace As String, strFilter As String
Llama.sDlgTitle = Caption$
' use below to call save dialog
Llama.flags = OFS_FILE_SAVE_FLAGS
lngReturn = GetSaveFileName(Llama)
If lngReturn Then
vbdShowSave = Llama.sFile
End Function
Now, to use this in your routine: below id a sample sub that pops open a dialog box for saving, and it seeds the initial file name with the current drawing name. if the user clicks cancel, the routine returns an empty filename. If the user accepts, then the FULL PATHSPEC of the filename is returned. Note that this routine DOES NOT actually save your drawing, you can add your own code for that.
Sub TestSaveAs()
Dim Filename As String: Filename = ThisDrawing.Name
Dim FileExt As String: FileExt = "*.dwg"
Dim FileDesc As String: FileDesc = "My Acad Drawings"
SaveFile Application.hwnd, Filename, FileExt, FileDesc, "Save this sucka"
If Filename = "" Then
MsgBox "User cancelled"
Else
MsgBox "Put in code to save drawing here!" & _
vbCrLf & "Name to save:" & vbCrLf & Filename
End Sub
