ObjectCollection to include X-Ref objects
faugustom
faugustom
Hi Everybody,
There is a way to include objects in X-Ref to de included in the ObjectCollection from this code?
(context: it's a vbscrpit used in a Property Set Definition from AutoCAD Architecture to calculate the total lenght of specific walls ([Style]. Actually, it only calculate the walls present in the current drawing).
Thank's
Set app = GetObject (,"AutoCAD.Application")
On Error Resume Next
RESULT = "--"
Set baseApp = app.GetInterfaceObject("AecX.AecArchBaseApplication.8.4")
Set ActiveDoc =baseApp.ActiveDocument
Set ObjectCollection = ActiveDoc.ModelSpace
totLength = 0
s = "[Style]"
For Each Object In ObjectCollection
If Object.StyleName = s Then
totLength = totLength + Object.Length
End IF
Next
RESULT = totLength/100
Ed__Jobe
In your iteration of modelspace, you would come across a BlockReference object representing an INSERT. Use the BlockReference.Name property to get the Block object from the block table. If Block.IsXref =true, then get
Block.XrefDatabase. Now iterate the xref db's modelspace for the walls.
Ed
How to post your code.
faugustom
Hello Ed,
Thank you for the response, but... I don't know how to write code (it's not mine, already used in the company). Besides I understand the guide lines, I have no ideia how to write... it would be to much to ask this? 🙂
Ed__Jobe
Sorry, Right now I don't have the time to write the code and test it for scripting. Not sure when I will be free.
Ed
grobnik
faugustom
Hi everyone!
Without much success, I tried to edit the code to find the block, identify the Xref, then get objects form its ModelSpace.
Any direction would be very apreciated, thanks
RESULT = "--"
totLength = 0
'this is the type of walls lenght to be calculated
s = "[Style]"
Next
'At this point, all objects in current drawing are being calculated
'Now it must find blocks
Set Blk = AcadBlock
'Search for blocks in ModelSpace blocks
For Each Blk In ObjectCollection.Blocks
  'Ask if the block is a XRef
   If Blk.IsXref = True Then
    'ok, it's a XRef, now scan it's modelspace for Objects
    For Each Object In Blk.XRefDatabase.ModelSpace
      'repeat the same routine
    Next
Next
RESULT = totLength
faugustom
Solved!
Now, the PSD is calculating the total length based on the style and then on the height of the walls. Fisrt it looks for objects in Blocks (Xref's) and then in other objects of the drawing.
RESULT = "--"
Set ActiveDoc = baseApp.ActiveDocument
Set BlocksCollection =  ActiveDoc.Blocks
totLength = 0
s = "[Style]"
h = "[DimsAlturamm]"
For Each Block In BlocksCollection
	IF Block.IsXref = True Then
		Set XrefCollection = Block.XRefDatabase.ModelSpace
		For Each Object In XrefCollection
				If CStr((Object.BaseHeight)*100) = h Then
				End IF
			End IF
		Next
	End IF
Next
	IF Object.StyleName = s Then
		End IF
	End IF
Next
RESULT = totLength
