Object viewer in VBA
nzeeben
Autodesk Autodesk
nzeeben
This is more of a land issue, but I want to launch a vba dialog with a portion of my AutoCAD dwg being shown within that dialog, is this even possible?
Hi, I can't answer your first question, but a work around may be open your form in one corner of the screen and to do a zoom window to the area you want to display (with experiment you should be able to get the relevant window corners) -- Laurie Comerford CADApps www.cadapps.com.au "nzeeben" wrote in message news:4067618.1097261427801.JavaMail.jive@jiveforum2.autodesk.com... > This is more of a land issue, but I want to launch a vba dialog with a portion of my AutoCAD dwg being shown within that dialog, is this even possible?
Depends on what you want to do with it but if its only for displaying, you could order your macro to export a portion of the dwg to a wmf and then read it back in your form. -- Saludos, Ing. Jorge Jimenez Ulate SICAD S.A., Costa Rica "nzeeben" escribió en el mensaje news:4067618.1097261427801.JavaMail.jive@jiveforum2.autodesk.com... > This is more of a land issue, but I want to launch a vba dialog with a > portion of my AutoCAD dwg being shown within that dialog, is this even > possible?
nzeeben
Ideally I would like to do something similar to what the quick section command in Land Desktop shows.
Hi, I think you will find that requires serious programming. If it's for in house use, I'm sure it would be cheaper to buy Land Desktop. If it's for commercial use, you should find a professional programmer and get him to help. -- Laurie Comerford CADApps www.cadapps.com.au "nzeeben" wrote in message news:96081.1097555060037.JavaMail.jive@jiveforum1.autodesk.com... > Ideally I would like to do something similar to what the quick section command in Land Desktop shows.
nzeeben
I am writing something for civil 3D, and want to emulate some land behavior.
