How to run a VBA Macro on Autocad
How can I run or call a command that I made in VBA by typing its name on command line or pushing an icon on the menu bar ?I know that i can use VBAIDE,VBARUN,...,but I need to run my VBA like I am using COPY command (for example). Thanks, Afshin.
"A-Design" wrote in message news:4166e1d4$1_3@newsprd01... > How can I run or call a command that I made in VBA by typing its name on > command line or pushing an icon on the menu bar ?I know that i can use > VBAIDE,VBARUN,...,but I need to run my VBA like I am using COPY command (for > example). Thanks, I have a lisp routine that defines several macros to commands. A sample: (defun RunVbaMacro ( sFileName sMacroName / fnam fullname) (if (setq fullname (findfile sFileName)) (progn (vl-vbaload fullname) (vl-vbarun sMacroName) (command "vbaunload" sFileName) );progn (alert (strcat sFileName " cannot be located!\nGive IT Dept this file name!")) );if );defun (defun C:STH ( / ) (RunVbaMacro "DimensionTextControl.dvb" "DimensionTextControl.dvb!mUserMacros.ShowTextSettings") (princ) ) (defun C:LAG ( / ) (RunVbaMacro "CecLayerTools.dvb" "CecLayerTools.dvb!mUserMacros.LayerGroups") (princ) ) The result of the two listed are commands STH and LAG, which can be issued at the command prompt.
Check out www.caddzone.com & look for a lisp routine called autovbaload.lsp it is similar to autoload for lisp but will load and run vba macros
Hi, You may care to look at my post in the Land Desktop Customisation Group under "Civil Desktop not loaded" on 8 Oct. -- Laurie Comerford CADApps www.cadapps.com.au "A-Design" wrote in message news:4166e1d4$1_3@newsprd01... > How can I run or call a command that I made in VBA by typing its name on > command line or pushing an icon on the menu bar ?I know that i can use > VBAIDE,VBARUN,...,but I need to run my VBA like I am using COPY command (for > example). Thanks, > > Afshin. > >
Thanks for the responses "Laurie Comerford" wrote in message news:4166fbbd_1@newsprd01... > Hi, > > You may care to look at my post in the Land Desktop Customisation Group > under "Civil Desktop not loaded" on 8 Oct. > > -- > > > Laurie Comerford > CADApps > www.cadapps.com.au > > "A-Design" wrote in message > news:4166e1d4$1_3@newsprd01... > > How can I run or call a command that I made in VBA by typing its name on > > command line or pushing an icon on the menu bar ?I know that i can use > > VBAIDE,VBARUN,...,but I need to run my VBA like I am using COPY command > (for > > example). Thanks, > > > > Afshin. > > > > > >
