object snap mode
object snap mode
object snap mode
I want to access to object snap mode (such as mid, center , ....) with VBA. This is possible in Lisp , but i can't find anythings in VBA . please help me.
Try
ThisDrawing.Setvariable "OSMODE", [integer number goes here]
~'J'~
ok, and then ??? How I can use of midpoint,center,...???
go to autocad, now to to help and search up osmode, its called "OSMODE System Variable" ,under command. there is a list of values you can set osmode to. To set a varibable using visual basic, do
ThisDrawing.SetVariable "OSMODE", 0 -- for example.
~cheers
Ok. Thanks . How can I use Osnap without "GetPoint" , this means that one of point of osnap be a peoperty of an object such as EndPoint.
