'obejct was open for read' Please help
Message 1 of 19
hi
i have a routine that attaches xdata to a block. i also have a
'acadobject_modified' event that if i move the block is supposed to update
that xdata with the new block position, the problem is that when i go to
'setXdata' an error msg is displayed with 'object was open for read'....
firstly, what does this mean? secondly, is there a way around this???
thanks in advance
cheers
mark
Replies (18)
Message 2 of 19
It means that you are receiving the 'acadobject_modified' notification while
the block reference is in the process of being updated (moved). Therefore
the object (block reference) is not able to be modified at that moment.
You can probably accomplish what you are after by recording the ObjectId of
the block reference in a global variable in the 'acadobject_modified' event.
Then, in the 'end_command' event, you could use
ThisDrawing.ObjectIDToObject() on the stored ObjectId to get a reference to
the block reference and update the xdata.
"Mark Dubbelaar" wrote in message
news:6660E2963421F87FDB79CE6DB68CF921@in.WebX.maYIadrTaRb...
> hi
> thanks in advance
> cheers
> mark
Message 3 of 19
Not easily. You might try using an extension dictionary
with an XRecord, since that's a separate object that
can be opened from its owner's ObjectModified event
handler.
"Mark Dubbelaar" wrote in message news:6660E2963421F87FDB79CE6DB68CF921@in.WebX.maYIadrTaRb...
> hi
> thanks in advance
> cheers
> mark
Message 4 of 19
Can you not use dxf-code 1011, which is World Space Position?
R. Robert Bell, MCSE
www.AcadX.com
| hi
| thanks in advance
| cheers
| mark
Message 5 of 19
Hi Mark,
I had in the past considered keeping some data with a block and at first was
thinking to include the position in the list of xdata also.
Then I realized the block already carries all it's "self information"
including it's position in it's own entity list, and since I would have
needed to get that entity list to get it's xdata anyway, I decided I was
overcomplicating what I wanted to do...
Don't know what your plans are or if that makes any sense to you in the
context of your routine or not, but just thought I'd share my
thoughts...(for what it's probably *not* worth!)
other Mark
> hi
Message 6 of 19
Mark,
1. There should really be no need to store xdata regarding the
block's position since it is relatively easy to access the insertion
point (DXF code 10)
2. There should be no need to update xdata relating to the postion
of the block since if you store the xdata under the code that Robert Bell
mentioned it is updated automatically.
3. If you really want to do this, the error comes from the fact
that you can not modify an object during the object modified event.
You must set a flag and then use another reactor (such as the
command ended reactor) to make the xdata change. The command_ended
reactor should set a flag that can be read by your object modified reactor
so that it ignores the xdata change.
> hi
> thanks in advance
> cheers
> mark
Message 7 of 19
not to sure who i should reply too.....
what i am trying to achieve is a block which is 'attached' to a viewport...
by this i mean that when the user moves the viewport i won't the block to
move in a relative position, so what i am trying to do, is save the relative
position (distance, angle) to the viewport centre and then when the object
modified event is triggered, get the new viewport centre and move the block
accordingly...
the 'object was open for read' happens when i move the block instead of the
viewport, and using the object modified event again, save the new relative
location in the xdata of the block....
i have another question regarding the 'object_modified' event... if i zoom /
pan in the viewport the object_modified event is not triggered.... i'm
assuming you can use the endcommand event to trap this, but i was wondering
why the object_modified event is not triggered???
cheers, and thanks for the advice
mark
"Doug Broad" wrote in message
news:9DB683FF48BE98DC54A60C64EC5BFD29@in.WebX.maYIadrTaRb...
> Mark,
> point (DXF code 10)
> > hi
update
> > thanks in advance
> > cheers
> > mark
Message 8 of 19
I've never done any Event programming in ACAD, but to me it seems like you
need to separate your data a little so that when you move the block, you
change data on the VPORT object, and vice versa. The way I would do that
(and I think save you from having to do distance / angle calc's) would be to
store the current VPORT center in the block object's data. That way, if you
move the block, nothing happens (the VPORT has not moved). If you move the
VPORT, in the Modified event that fires AFTER the move is done, move the
block by the vector
old X, Y, Z stored in block data --> new X, Y, Z taken from Viewport
object
and in the same event, store the new VPORT X, Y, Z in the block's data (i.e.
new XYZ becomes old XYZ).
In code it would be something like:
Dim oBlock as AcadBlock 'module level
dim oVP as AcadViewport 'module level
Sub Object_Modified (obj as Object):
if obj = oVP
oBlock.Move ...
oblock.SetXData ...
endif
end sub
Sub Drawing_Initialize ' or whatever runs when you open a drawing
Set oBlock = ...
Set oVP = ...
end sub
If the module-level objects won't stay in memory between event calls, you
might be able to make them Static variables within the event (again... no
ACAD event programming experience here, just thoughts). The key is to give
the viewport some way to remember which block it's supposed to be
reading/writing to.
In a nutshell, the whole point of my post is to avoid having an object
modify itself... hope this helps.
James
Message 9 of 19
Hi Mark,
I'm not an AutoCAD guy, but aren't there things called AutoCAD groups which
allow you to move objects as a group ?
In that case all you need do is create a group of your block and the Vport
and move the group.
Laurie Comerford
CADApps
www.cadapps.com.au
news:156EAFAC382FBCCCB65121E84B4DD4B7@in.WebX.maYIadrTaRb...
viewport...
relative
block
> accordingly...
the
wondering
> mark
> > Mark,
> > point (DXF code 10)
Bell
reactor
> > > hi
> update
to
read'....
> > > thanks in advance
> > > cheers
> > > mark
Message 10 of 19
arcticad
This is a General Program for modifying Objects that have been modified, It Creates an array of all the Handles then acts on those objects in endcommand
Dim Gvar As Variant
Dim Gcheck As Boolean
Private Sub AcadDocument_ObjectModified(ByVal object As Object)
If Gcheck = True Then Exit Sub
Gvar = code.inc(Gvar)
Gvar(UBound(Gvar)) = object.handle
End Sub
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
Dim handle As Variant
On Error GoTo theend
Gcheck = True
For Each handle In Gvar
Set object = ThisDrawing.HandleToObject(handle)
'do stuff to the object
Next
theend:
Gcheck = False
Set Gvar = Nothing
End Sub
Function inc(myarray As Variant) As Variant
Dim temparray() As Variant
If isArrayValid(myarray) Then
ReDim Preserve myarray(UBound(myarray) + 1)
Else
ReDim myarray(0)
End If
inc = myarray
End Function
Function isArrayValid(myarray As Variant) As Boolean
Dim item As Variant
For Each item In myarray
isArrayValid = True
Exit Function
Next
theend:
isArrayValid = False
End Function
(defun botsbuildbots() (botsbuildbots))
Message 11 of 19
Based on the subject line "Object was open for read" and the code you have
shown in the event handler(s) it appears that you may be trying to modify
the object that triggered the event.
AutoCAD 2004 Developer Help > Use Events > Guidelines for Event Handlers
You can write data to any object in the database, except the object that
issued the event.
Obviously, any object causing an event to be triggered could still be open
for use with
AutoCAD and the operation currently in progress. Therefore, avoid writing
any information
to an object from an event handler for the same object.
If you put the snip below in the "ObjectModified" event it will give the
error you see. It violates the rule (above) and trys to modify the object
that has triggered the event.
Private Sub AcadDocument_ObjectModified(ByVal Object As Object)
Object.color = acRed
End Sub
You will have to make whatever modification you are attempting after you
exit the event handler(s)
HTH,
Gary
wrote in message news:4849483@discussion.autodesk.com...
Dim Gvar As Variant
End Sub
Gcheck = True
Next
theend:
Gcheck = False
Set Gvar = Nothing
End Sub
Else
ReDim myarray(0)
End If
inc = myarray
End Function
Dim item As Variant
isArrayValid = True
Exit Function
Next
theend:
End Function
Message 12 of 19
arcticad
The Program just gathers up the information from the modified event.
It doesn't try to change anything.
The Handles are stored in a Global Variable Array.
Then the EndCommand Event Gets the List and Makes the Changes.
This doesn't violate anything.
Message 13 of 19
I hope I didn't mislead you.
Your comment " 'do stuff to the object" in the EndCommand event suggested
that you were attempting modification.
Gary
Message 14 of 19
The above assumes that the events occur as one would be led to believe:
Begin_Command
Object_Modified
End_Command
Not always true.
(Same help section cited previously:)
Do not rely on the sequence of events.
Gary
Message 15 of 19
arcticad
Yes I Agree that the documentation says you can not rely on the sequence of events. However I have never seen a time when object modified event was triggered after the command finished.
If you can give me a way to show this i would be very interested.
Thank you.
Message 16 of 19
Object Modified could be getting triggered before the End Command but hasn't
finished modifying the object. Thus the error "object was open for read".
I don't know how you could prove it other than passing your array to a sub
outside of the event handler to see if the problem goes away. If you are
doing extensive mods to the object maybe you could temporarily change it to
something simple to see if the problem goes away.
Gary
wrote in message news:4854763@discussion.autodesk.com...
Thank you.
Message 17 of 19
I am recieving this same error message 'object was open for read' in AutoCAD 2008 when using annotative objects.
I'm not using any lisp routines of any kind when encountering this problem.
Its also inconsistent, in other words it only happens sometimes, so there has to be something that either I am doing, or the program is doing that is affecting my objects in such a way that its giving me this problem.
as I said, its annotative objects that are giving me the problem. I am unable to move them, rotate them, edit them, or even erase them. they behave almost exactly like an object on a locked layer, except that the layer isn't locked.
So my question here is twofold I suppose:
first off, how do I 'release the lock' for lack of a better term, and secondly, what is causing it to happen.
Thanks for any help you can give.
Message 18 of 19
Can you post some sample code?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5813954@discussion.autodesk.com...
Message 19 of 19
Anyone have an answer yet? Annotative is great untill OPEN FOR READ pops up. The only solution I have found is to save and reopen and wait for it to happen again.
