not the right result
to all,
I am trying to plot drawings that are sent to me from Thailand. For that I
am using the next routine.
Public Sub dsmplot()
Dim AcadPref As AcadPreferencesOutput
Set AcadPref = ThisDrawing.Application.Preferences.Output
If ThisDrawing.ActiveSpace = acPaperSpace Then
ThisDrawing.MSpace = True
ThisDrawing.ActiveSpace = acModelSpace
End If
AcadPref.DefaultOutputDevice = "HP LaserJet 1100"
AcadPref.DefaultPlotStyleTable = "D:\ACAD2000\Plot Styles\WML_pids_015.ctb"
ThisDrawing.ModelSpace.Layout.PlotType = acExtents
ThisDrawing.ModelSpace.Layout.StandardScale = acScaleToFit
ThisDrawing.Plot.NumberOfCopies = 1
ThisDrawing.Plot.PlotToDevice
End Sub
the only problem is; " it doesn't work" . Is there somebody that can shine
his/her light?
René
Rene,
At a quick glance, I'd say try changing your last line of code form:
to:
ThisDrawing.Plot.PlotToDevice ThisDrawing.ActiveLayout.ConfigName
Hopefully, this will do the trick, otherwise let me know the error message and
where it's stalling out in the program.
-Josh
Rene van Kwawegen wrote:
> to all,
> End If
> End Sub
> his/her light?
> Regards,
> René
Oops, almost forgot,
thisdrawing.activelayout.configname = "HP LaserJet 1100.pc3"
-Josh
Minkwitz Design wrote:
> Rene,
> to:
> -Josh
> > to all,
> > End If
> > End Sub
> > his/her light?
> > Regards,
> > René
Hi all again,
I did not change much in my routine. I only placed the device name behind
the PlotToDevice.
I recieve a plot from the right printer so that is ok.
What does not work is the codeline with the plotstyle call.
AcadPref.DefaultPlotStyleTable = "D:\ACAD2000\Plot Styles\DSM-iso.ctb"
I made a small routine to find the Plotstyle in use, that works fine, but
then I cannot use the
result to call the right "ctb". The code I found all over is only to change
the plotstyle in the A2K
options. That only works for new made drawings.
Public Sub FindStyle()
Dim StTable As Variant
Dim StNr As Integer
Dim StName As String
ThisDrawing.ActiveLayout.RefreshPlotDeviceInfo
StTable = ThisDrawing.ActiveLayout.GetPlotStyleTableNames
For StNr = LBound(StTable) To UBound(StTable)
StName = StTable(StNr)
Next StNr
End Sub
TIA,
René
Try using:
const MyStyle = "D:\ACAD2000\Plot Styles\DSM-iso.ctb"
AcadPref.DefaultPlotStyleTable = MyStyle
I know it's supposed to a read/write string value, but the help example shows
it as a constant. Please post and let me know if it works.
-Josh
> Hi all again,
> the PlotToDevice.
> Dim StNr As Integer
> Next StNr
> End Sub
> TIA,
> René
