Need help with some code involving Excel
The following code is the code i have for opening an existing excel spreadsheet, and the other sub after is for putting data into excel. However I continue to get a "Runtime - error "424" Object Required" error for whichever listindex i choose. I have surrounded the code with error in *'s. Is this possibly something to do with my excel open code being wrong? or am i just missing something?
Private Sub OpenExcel_Click()
Dim oExcel As Excel.Application
Dim oBook As Excel.Workbook
Dim oSheet As Excel.Worksheet
'Open Excel
Set oExcel = New Excel.Application
oExcel.Visible = True
Set oBook = oExcel.Workbooks.Add("\\fscs\Students\curtisno\Desktop\217ExcelCost.xls")
Set oSheet = oBook.Sheets("UnitCosts")
oExcel.DisplayAlerts = False
'Save new file
Dim ExcelFileName As String
Dim msg1 As Variant
'open SaveAs dialog
CommonDialog1.ShowSave
'define the name for new file. When Save button is clicked, new file is created and saved.
ExcelFileName = CommonDialog1.FileName
'just the note for user if Cancel button is clicked
If ExcelFileName = "" Then
msg1 = MsgBox("You didn't create a file.", vbOKOnly, "Note")
Exit Sub
'Call oBook.Close(True, "C:\myFile1.xls")
Call oBook.Close(True, ExcelFileName)
oExcel.DisplayAlerts = True
oExcel.Quit
Set oSheet = Nothing
Set oBook = Nothing
Set oExcel = Nothing
End Sub
Private Sub ExteriorGet_Click()
Dim pt1, pt2 As Variant
Dim objPline As AcadLWPolyline
Dim Points() As Double
Dim distanceEXT As Double
Dim areaEXT As Double
UserForm1.Hide
On Error Resume Next
pt1 = ThisDrawing.Utility.GetPoint(, "Enter First Point")
If Err.Number <> 0 Then Exit Sub
ReDim Points(1)
Points(0) = pt1(0): Points(1) = pt1(1)
i = 1
Do
pt2 = ThisDrawing.Utility.GetPoint(pt1, "Enter Next Point")
If Err.Description <> "User input is a keyword" Then
i = i + 2
ReDim Preserve Points(i)
Points(i - 1) = pt2(0)
Points(i) = pt2(1)
objPline.Delete
Set objPline = ThisDrawing.ModelSpace.AddLightWeightPolyline(Points)
objPline.Update
pt1 = pt2
Else
Exit Do
Loop
distanceEXT = objPline.Length
areaEXT = objPline.Area
objPline.Delete
distanceEXTa = distanceEXT
areaEXTa = areaEXT
UserForm1.Show
On Error GoTo 0
If FoundationTypeBox.ListIndex = 0 Then
oSheet.Cells(3, 4).Value = (Worksheet.Cells(3, 4).Value + distanceEXT)
ElseIf FoundationTypeBox.ListIndex = 1 Then
oSheet.Cells(4, 4).Value = (Worksheet.Cells(4, 4).Value + distanceEXT)
ElseIf FoundationTypeBox.ListIndex = 2 Then
oSheet.Cells(5, 4).Value = (Worksheet.Cells(5, 4).Value + distanceEXT)
Else: MsgBox "No Foundation Type Selected."
If FloorSlabBox.ListIndex = 0 Then
oSheet.Cells(7, 4).Value = (Worksheet.Cells(7, 4).Value + areaEXT)
ElseIf FloorSlabBox.ListIndex = 1 Then
oSheet.Cells(8, 4).Value = (Worksheet.Cells(8, 4).Value + areaEXT)
ElseIf FloorSlabBox.ListIndex = 2 Then
oSheet.Cells(9, 4).Value = (Worksheet.Cells(9, 4).Value + areaEXT)
Else: MsgBox "No Floor Slab Selected."
If ExteriorWallBox.ListIndex = 0 Then
oSheet.Cells(11, 4).Value = (Worksheet.Cells(11, 4).Value + distanceEXT)
ElseIf ExteriorWallBox.ListIndex = 1 Then
oSheet.Cells(12, 4).Value = (Worksheet.Cells(12, 4).Value + distanceEXT)
ElseIf ExteriorWallBox.ListIndex = 2 Then
oSheet.Cells(13, 4).Value = (Worksheet.Cells(13, 4).Value + distanceEXT)
Else: MsgBox "No Exterior Wall Selected."
If RoofStructureBox.ListIndex = 0 Then
oSheet.Cells(52, 4).Value = (Worksheet.Cells(52, 4).Value + areaEXT)
ElseIf RoofStructureBox.ListIndex = 1 Then
oSheet.Cells(53, 4).Value = (Worksheet.Cells(53, 4).Value + areaEXT)
Else: MsgBox "No Roof Structure Selected."
If RoofMaterialsBox.ListIndex = 0 Then
oSheet.Cells(55, 4).Value = (Worksheet.Cells(55, 4).Value + areaEXT)
ElseIf RoofMaterialsBox.ListIndex = 1 Then
oSheet.Cells(56, 4).Value = (Worksheet.Cells(56, 4).Value + areaEXT)
ElseIf RoofMaterialsBox.ListIndex = 2 Then
oSheet.Cells(57, 4).Value = (Worksheet.Cells(57, 4).Value + areaEXT)
ElseIf RoofMaterialsBox.ListIndex = 3 Then
oSheet.Cells(58, 4).Value = (Worksheet.Cells(58, 4).Value + areaEXT)
Else: MsgBox "No Roof Materials Selected."
End Sub
sorry the error code is...
depending on which listindex i choose, there is an error reguardless just the selected line of code
I'm not certain of it, but the line you cited below looks like it should be:
oSheet.Cells(3, 4).Value = oSheet.Cells(3, 4).Value + distanceEXT
or possibly (among others):
ActiveSheet.Cells(3, 4).Value = ActiveSheet.Cells(3, 4).Value + distanceEXT
You shouldn't be using "WorkSheet" as a variable if that's what you're
trying to do. VBA keywords, method & property names etc should be off limits
for variable names.
sorry, i was changing variable names and forgot to switch that part out, but the same error resides reguardless as the label was not the problem. any thoughts on why this is? i assume still that is a problem with my linking to excel code and not inserting the values?
Try connecting using "CreateObject" and/or "GetObject" to see if that makes
a difference.
'测量面积
Function CalculateDefinedArea()
Dim j As Integer
Dim j1 As Integer
Dim i As Integer
Dim p1 As Variant
Dim jp(0 To 2) As Double
Dim p2(200) As Double
Dim p3() As Double
Dim Line1(200) As AcadLine
AppActivate AcadApp.Caption '换到CAD窗体
' 获取用户输入的点
j1 = 0
Do
If j1 = 0 Then
p1 = AcadApp.ActiveDocument.Utility.GetPoint(, "测量面积功能,请选取第" & j1 + 1 & "点: ")
If Err Then
Err.Clear
Exit Function
ElseIf j1 = 1 Then
p1 = AcadApp.ActiveDocument.Utility.GetPoint(p1, "测量面积功能,请选取第" & j1 + 1 & "点: ")
If Err Then
Err.Clear
Exit Function
Else
If Err Then
Err.Clear
Exit Do
p2(j) = p1(0)
p2(j + 1) = p1(1)
If j1 > 0 Then
Set Line1(j1) = AcadApp.ActiveDocument.ModelSpace.AddLine(p1, jp)
Line1(j1).Color = acBlue
Line1(j1).Lineweight = acLnWt050
Line1(j1).Update
jp(0) = p1(0)
jp(1) = p1(1)
jp(2) = p1(2)
j = j + 2
j1 = j1 + 1
Loop
'ReDim line1(j1) As AcadLine
For i = 1 To j1
Line1(i).Delete
Next
' 根据这些点创建二维多段线
Dim polyObj As AcadLWPolyline
ReDim p3(0 To (j - 1)) As Double
For i = 0 To j - 1
p3(i) = p2(i)
Next i
Set polyObj = AcadApp.ActiveDocument.ModelSpace.AddLightWeightPolyline(p3)
polyObj.Closed = True
polyObj.Color = acGreen
polyObj.Lineweight = acLnWt060
polyObj.Highlight (True)
' 显示多段线的面积
'MsgBox "The area defined by the points is " & _
' polyObj.Area, , "Calculate Defined Area"
mianji = Int(polyObj.Area * 0.0001) * 0.01
'Form3.Visible = True
' Form3.Label1.Caption = "面积计算" & mianji
If Form1.Check1.Value = 1 Then
Dim NewLayer As AcadLayer
Set NewLayer = AcadApp.ActiveDocument.Layers.Add("mianji")
AcadApp.ActiveDocument.ActiveLayer = NewLayer
'文字
' Dim styobj1 As AcadTextStyle
' Set styobj1 = AcadApp.ActiveDocument.TextStyles.Add("设计")
' typeface = "宋体"
'定义文本对象
Dim textobj As AcadText
'Dim textstring As String
'Dim insertionpoint(0 To 2) As Double
Dim height As Double
Dim blockObj As AcadBlock
height = 200
If Form1.Check7.Value = 0 Then
Form1.StatusBar1.Panels(1).Text = "请选择面积数: """ & mianji & "平方米"" 标注位置"
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0
insertionPnt(1) = 0
insertionPnt(2) = 0
Set blockObj = AcadApp.ActiveDocument.Blocks.Add(insertionPnt, "text2")
' 向块中添加圆
Set textobj = blockObj.AddText(mianji & "m2", insertionPnt, height)
AcadBlock11 blockObj
AcadApp.ActiveDocument.SendCommand "_EXPLODE " & "L " & vbCr 'Explode last item
Else
p1(0) = (p3(0) + p3(4)) * 0.5 - 600
p1(1) = (p3(1) + p3(5)) * 0.5 - 600
p1(2) = 0
Set textobj = AcadApp.ActiveDocument.ModelSpace.AddText(Str(mianji) & "平方米", p1, height)
textobj.Update
polyObj.Delete
End Function
do like this is right
TempSheet1.Cells(hj, 1) = hj 'hj string
TempSheet1.Cells(hj, 3) = List2.List(List2.ListIndex)
TempSheet1.Cells(hj, 4) = List3.List(List3.ListIndex)
TempSheet1.Cells(hj, 5) = List1.List(List1.ListIndex)
TempSheet1.Cells(hj, 6) = List4.List(List4.ListIndex)
TempSheet1.Cells(hj, 7) = Text1.Text
TempSheet1.Cells(hj, 8) = Text3.Text
TempSheet1.Cells(hj, 9) = Text4.Text
