Message 1 of 1
Application Event Redux.
I am having an issue. I want to check the file before it opens.
This works fine as long as I have already opened at least 1 file.
(VBA has already been initialized)
If Autocad is closed then
When I double click on a drawing and autocad opens then the drawing loads then VBA initializes.(too late)
I want to prevent it from loading untill I can check the file.
Then let it continue to load.
Thanks.
This is in acad.dvb
Dim X As New EventClassModule
Sub InitializeEvents()
Set X.ACADApp = ThisDrawing.Application
End Sub
Sub INITEVENTS()
Call InitializeEvents
End Sub
Sub AcadStartup()
INITEVENTS
End Sub
class file named EventClassModule
Public WithEvents ACADApp As AcadApplication
Private Sub ACADApp_BeginOpen(FileName As String)
MsgBox "A drawing is about to be loaded from: " & FileName
End Sub
Thanks.
This is in acad.dvb
End Sub
Sub INITEVENTS()
End Sub
Sub AcadStartup()
INITEVENTS
End Sub
End Sub
(defun botsbuildbots() (botsbuildbots))
