Need help with hole depth macro
Bryan_Shoff
Observer Observer
Bryan_Shoff
Observer
Observer
I'm trying to write a macro for Powermill that will limit the z depth for a threadmill or drill. I want to be able to select multiple hole feature sets that have different depths but for the ones that are deeper than the cutting length of my tool I want it to know that it can not go past a specific depth. Any help is much appreciated
thanks
Bryan
Ed__Jobe
You haven’t given any information regarding your environment or shown any code. Are you working with AutoCAD? 2D or 3D? Help us out a little.
Ed
How to post your code.
Bryan_Shoff
Observer
Observer
Hi Ed,
I'm using Powermill. The code I currently have is this
IMPORT TEMPLATE PROJECT FILEOPEN
"REFRENCE\T30 .500-13 Thriller_Guhring_Threadmilling OP.ptf"
MACRO PAUSE "SELECT FEATURESET"
EDIT FEATURESET ; DIAMETER ".422"
EXPLORER SELECT Toolpath "Toolpath\T30 .500-13 Thriller_Guhring_Threadmilling OP" NEW
EDIT PAR SELECTED WORKPLANE
EDIT PAR SELECTED BLOCK
ACTIVATE Toolpath "T30 .500-13 Thriller_Guhring_Threadmilling OP"
EDIT DATAFROMTOOL ;
EDIT TOOLPATH ; CALCULATE
EDIT TOOLPATH SAFEAREA RESET
RESET TOOLPATH RAPID
MACRO PAUSE "WARNING!!!!! CHECK Z DEPTH IS LESS THAN 1 INCH"
DIALOGS MESSAGE ON
DIALOGS ERROR ON
Ed__Jobe
I’m sorry but that’s not VBA. If you’re using a script for software called powermill, why are you asking in a forum for AutoCAD VBA?  You should be looking here
Ed
Bryan_Shoff
Observer
Observer
Ok I feel dumb. It's pretty obvious I haven't used these forums before. Thanks for the link Ed, I appreciate it
