mviewports adskunsupp2004.arx
Message 1 of 16
is this a file that exists, and does anyone know where i can download it?
i'd like to create an application that shows the frozen/thawed layers in paperspace viewport states for each layer in given mviewports and then be able to freeze and thaw layers in the same.
the difference being you wouldn't need to click in each viewport and set them with vplayer command or layer command.
is this possible with 2004?
thanks for any ideas
thanks
Replies (15)
Message 2 of 16
I'd think you could do this without that arx
the list of layer names is in xdata on the vport object
wrote in message news:6029809@discussion.autodesk.com...
thanks
Message 3 of 16
i actually researched this, but don't know if the format has changed for 2004... methods include capturing existing settings of a viewport and redrawing it and various 3rd party (undependable) .arx. do you have any examples for this?
Message 4 of 16
wrote in message news:6029822@discussion.autodesk.com...
examples for this?
Sub testvplayer()
On Error GoTo testvplayer_Error
Dim bSuccess As Boolean
Dim ovp As AcadPViewport, oent As AcadEntity, vp, vList As Variant
ThisDrawing.Utility.GetEntity oent, vp, "Pick vport"
Dim i As Long
If TypeOf oent Is AcadPViewport Then
Set ovp = oent
vList = VpLayerList(oent)
For i = LBound(vList) To UBound(vList)
Debug.Print vList(i)
Next
ExitHere:
On Error GoTo 0
Exit Sub
testvplayer_Error:
' LogError ProcName
Resume ExitHere
End Sub
Function VpLayerList(ovp As AcadPViewport) As Variant
On Error GoTo VpLayerList_Error
Dim XdataType As Variant
Dim XdataValue As Variant
Dim i As Long
Dim vRtn As Variant
ReDim alist(0) As String
' Get the Xdata from the Viewport
ovp.GetXData "ACAD", XdataType, XdataValue
For i = LBound(XdataType) To UBound(XdataType)
' Look for frozen Layers in this viewport
If XdataType(i) = 1003 Then
alist(UBound(alist)) = XdataValue(i)
ReDim Preserve alist(UBound(alist) + 1)
Next
If UBound(alist) > 0 Then
ReDim Preserve alist(UBound(alist) - 1)
VpLayerList = alist
ExitHere:
On Error GoTo 0
Exit Function
VpLayerList_Error:
'LogError ProcName
Resume ExitHere
End Function
hth
mark
Message 5 of 16
thanks mark,
but how would you go about freezing and then thawing say layer 0 in a given viewport?
Message 6 of 16
add and delete from that xdata list
slipping your names in in between the brackets of the section that holds
those names
hth
mark
wrote in message news:6029961@discussion.autodesk.com...
thanks mark,
viewport?
Message 7 of 16
thanks mark
i read about people finding that impossible to do, specifically thawing layers within a viewport without using a sendcommand, but i'll give it a try when have a little time. is this something you've tried yourself? or it just seems possible.
Message 8 of 16
This was posted some time back...maybe a long time?
I haven't had occasion to try it but it looks potentially sound in concept.
Code for freezing layer(s) in a PaperSpace Viewport (mview)
'frank.zander@contractcaddgroup.com
'Paste this code into the code window of a form.
'Then on the form create a button and from the button call the sub
selectVPobjectsToFreeze.
Option Explicit
'Dim ac As AcadApplication
'Dim ThisDrawing As AcadDocument
'Public Function GetAcad()
' On Error Resume Next
' Set ac = GetObject(, "AutoCAD.Application")
' If Err Then
' Err.Clear
' On Error GoTo 0
' Set ac = CreateObject("AutoCAD.Application")
' ac.Visible = True
' End If
'Set GetAcad = ac
'End Function
Sub form_load()
'Set ac = GetAcad
'Set ThisDrawing = ac.ActiveDocument
End Sub
Private Sub cmdSelect_Click()
Me.Hide
Unload Me
End Sub
Public Sub selectVPobjectsToFreeze()
Dim objEntity As AcadObject
Dim strLayer As String
Dim PT1 As Variant
Dim newSS As AcadSelectionSet
Dim vLayers() As Variant
On Error GoTo err_selectVPobjectsToFreeze
ThisDrawing.StartUndoMark
If ThisDrawing.ActiveSpace = acModelSpace Then
MsgBox "This program only works with PaperSpace Viewports" & vbCr & _
"Please go to PaperSpace", vbCritical
Exit Sub
ThisDrawing.MSpace = True
Set newSS = ThisDrawing.SelectionSets.Add("Vplayers")
ThisDrawing.Utility.Prompt ("Select Objects layers to freeze in the
viewport:" & vbCr)
newSS.SelectOnScreen
For Each objEntity In newSS
strLayer = objEntity.Layer
VpLayerOff (strLayer)
Next
ViewPortUpdate
newSS.Delete
ThisDrawing.EndUndoMark
Exit Sub
err_selectVPobjectsToFreeze:
MsgBox Err.Description, vbInformation
Err.Clear
End Sub
Sub ViewPortUpdate()
' Update the viewport...
Dim objPViewport As AcadObject
Set objPViewport = ThisDrawing.ActivePViewport
ThisDrawing.MSpace = False
objPViewport.Display (False)
objPViewport.Display (True)
ThisDrawing.Utility.Prompt ("Done!" & vbCr)
End Sub
Sub VpLayerOff(strLayer As String)
' make the layer non displayable (freeze) in the current Viewport
Dim objPViewport2 As AcadObject
Dim I As Integer
Dim Counter As Integer
Dim PT1 As Variant
' Get the active ViewPort
objPViewport.GetXData "ACAD", XdataType, XdataValue
For I = LBound(XdataType) To UBound(XdataType)
If XdataType(I) = 1003 Then
' Set the counter AFTER the position of the Layer frozen layer(s)
Counter = I + 1
' If the layer is already in the frozen layers xdata of this viewport
the
' exit this sub program
If XdataValue(I) = strLayer Then Exit Sub
Next
' If no frozen layers exist in this viewport then
' find the Xdata location 1002 and place the frozen layer infront of the "}"
' found at Xdata location 1002
If Counter = 0 Then
If XdataType(I) = 1002 Then Counter = I - 1
Next
' set the Xdata for the layer that is beeing frozen
XdataType(Counter) = 1003
XdataValue(Counter) = strLayer
ReDim Preserve XdataType(Counter + 1)
ReDim Preserve XdataValue(Counter + 1)
' put the first "}" back into the xdata array
XdataType(Counter + 1) = 1002
XdataValue(Counter + 1) = "}"
' Keep the xdata Array and add one more to the array
ReDim Preserve XdataType(Counter + 2)
ReDim Preserve XdataValue(Counter + 2)
' put the second "}" back into the xdata array
XdataType(Counter + 2) = 1002
XdataValue(Counter + 2) = "}"
' Reset the Xdata on to the viewport
objPViewport.SetXData XdataType, XdataValue
' notice that at this point NOTHING happens in the viewport to visibly show
' any changes to the viewport.
' flipping to a different layout or turning the Mview Off and On will
display the
' Xdata changes to the viewport.
' See sub ViewPortUpdate for how to update the Viewport.
End Sub
wrote in message news:6030709@discussion.autodesk.com...
thanks mark
Message 9 of 16
"MP" wrote in message
news:6030714@discussion.autodesk.com...
just tested it and seems to work nicely
Message 10 of 16
just noticed you were also talking about thawing....
the posted code of course freezes...
you should be able, using that as a guide, to write a function to thaw a
list of layer names
are you saying that if you remove a name from the list that it doesn't
properly thaw the layer???
mark
thanks mark
Message 11 of 16
thanks! great starting point and i now understand what you mean about thawing being the same as not frozen.
Message 12 of 16
The code for freezing by adding XData works, and works well. However, for some reason, doing the 'opposite' by removing the layers from the XData does *not* work for thawing. The code you posted was part of a series of routines that I, too , snagged off the NG's.
The "thaw" routine that was originally posted with it, does not use the XData method to thaw (because it doesnt work) but does work, but only by deleting, then recreating, the viewport and then freezing the layers in the new viewport.
I personally can't use this method, because our viewports have MTEXT blocks with fields attached (Like from the Sheet Set Manager) Erasing, then recreating the viewports 'hoses' the links. But if you dont use fields, the re-creation method works well.
Message 13 of 16
Thanks for the info
wrote in message news:6031333@discussion.autodesk.com...
new viewport.
how do you attach an Mtext block (you mean an mtext object???) to a vport?
mark
Message 14 of 16
once we place our views in pspace, we add view name references from the Sheet Set manager. These view name references are blocks, with Mtext and fields inside, that reference the ObjectID of the viewport itself. (Most fields use the ObjectID)
Erasing, then re-creating a viewport creates a totally different viewport, with its own unique ObjectID. The names of the viewports, and any section/elev/detail markers referenced anywhere in other drawings, then come out as nothing but "#########".
Message 15 of 16
wrote in message news:6031336@discussion.autodesk.com...
ah...haven't used the sheet sets yet
so you can't get the sheet set block from the vport object, then revise the
objectid with the new vport's id eh?
are they really using the objecdid and not the handle? doesn't that change
every time dwg is opened?
Message 16 of 16
thanks for the info rocheey, i wonder if the field links can be recreated while the viewport is being recreated...
