DYNAMIC Stretch in VBA
Im so fried.... If anyone knows what im doing wrong.. please slap me on the head and tell me...
Im just trying to modify an existing dynblk from a textbox in vba.
Private Sub CommandButton1_Click()
Dim Clientlogo As String
Clientlogo = TextBox1.Value & "#"
MsgBox Clientlogo
'Changes logo per Users Selections . .
Dim dybprop As Variant, i As Integer
Dim bobj As AcadEntity
For Each bobj In ThisDrawing.ModelSpace
If bobj.ObjectName = "AcDbBlockReference" Then
If bobj.IsDynamicBlock Then
If bobj.EffectiveName = "MONOPOLE" Then
dybprop = bobj.GetDynamicBlockProperties
For i = LBound(dybprop) To UBound(dybprop)
If dybprop(i).PropertyName = "BOTTOM" Then
dybprop(i).Value = Clientlogo
Next i
Next
Me.Hide
End Sub
dunno
you dont' seem to have any debug code in there to tell you what's going
on...
eg did you find a block....did it have the property....etc
is the block name capitalized? do you have Option Text Compare set?
wrote in message news:6029641@discussion.autodesk.com...
head and tell me...
MsgBox Clientlogo
''' preferred to .ObjectName....
If TypeOf bobj Is AcadBlockReference Then
''' If bobj.ObjectName = "AcDbBlockReference" Then
Next i
Next
Me.Hide
End Sub
Wow, Im new to this vba stuff. Do you know where I could find this information?
The Text Caps and names are correct. If i replace the 'clientlogo' with a number followed by a '#' it works fine. but the user needs to be able to type in the size of the sign. is there a way to do this?
I dont know if this is correct or not, but it works. I changed the DIM..... as String to Double.
Now it works. Incase someone else needs the helping hand.
Dim Bottom As Double
Bottom = TextBox1.Text
dybprop(i).Value = Bottom
Next i
Next
Next i
Next
that will bomb as soon as someone enters a non numeric character into
textbox
If IsNumeric(TextBox1.Text) Then
Bottom = cDbl(TextBox1.Text)'might as well make it explicit so its' clear in
your code what you're doing
Else
' Err.Raise BadEntry
I know nothing about dynblock properties, when you create them you give them
a data type?
mark
wrote in message news:6030255@discussion.autodesk.com...
Next i
Next
