MultiLeader color and Text fromat in VBA
I have created multileader in my VBA code. I want to set multileader color . i can set color by changing 'Color' option in General tab  through properties option. but how can i change that in VBA. I tried LeaderLineColor, but it didnt work. I wan to change the text font for mleader text string.
Dim leaderObj As AcadMLeader
   Dim points(0 To 8) As Double
points(0) = x: points(1) = y: points(2) = 0 points(3) = x + 0.5: points(4) = y + 0.5: points(5) = 0 points(6) = x + 0.8: points(7) = y + 0.8: points(8) = 0 Set leaderObj = ThisDrawing.ModelSpace.AddMLeader(points, 0) leaderObj.textString = textString leaderObj.TextHeight = 0.3 leaderObj.TextFrameDisplay = 1 leaderObj.Update ZoomAll
Ed__Jobe
I don't recommend changing the color. You should work with styles and layers. Leave the color ByLayer and change the layer property. To change the color of the leader text, change that in the dim style and set the style by using the StyleName property. e.g.
leaderObject.StyleName = "MyLeaderStyle"
The style must exist in the current dwg. If not, you can use the DimStyle.CopyFrom method to copy from a template.
Ed
How to post your code.
jeremye86
Thanks Ed, you have helped me so many times
Ed__Jobe
You're welcome.
Ed
