Multi Layer to single DWG
Message 1 of 11
Hi to everybody, pls some body has some suggestion concerning the way to convert a multi-layer drawing in single sheet drawings ? I'll try to explain more: I have a drawing made with several layers (more than 80) the scope is to produce a single dwg file for each layer, the name of the single file should be composed by the main file name plus .the name of the layer that usually is 001, 002 etc. Somebody has some suggestion ?? My idea was to copy all objects on the single layers and paste on a new dwgfile previously settled as the main file (I mean form, size, and so on !). Many thanks
Replies (10)
Message 2 of 11
Hallex
Try to use ObjectDBX methods, here is a sample
Option Explicit
' require reference to AutoCAD/ObjectDBX XX.X Library
Sub ImpotrtLayersAsDwg()
Dim oEnt As AcadEntity
Dim dbxDoc As AxDbDocument
Dim path As String
Dim dwgname As String
path = ThisDrawing.GetVariable("dwgprefix")
dwgname = ThisDrawing.GetVariable("dwgname")
On Error GoTo Err_Control
Dim oLayer As AcadLayer
Dim layColl As Collection
Set layColl = New Collection
Dim n
   For Each oLayer In ThisDrawing.Layers
     layColl.Add oLayer.Name
   Next
Dim itm
For Each itm In layColl
Dim setName As String
     setName = CStr(itm)
    Dim gpCode(1) As Integer
     Dim dataValue(1) As Variant
     Dim oSset As AcadSelectionSet
          With ThisDrawing.SelectionSets
               While .Count > 0
                    .Item(0).Delete
               Wend
          Set oSset = .Add(setName)
          End With
     gpCode(0) = 67: gpCode(1) = 8:
      dataValue(0) = 0: dataValue(1) = setName
     oSset.Select acSelectionSetAll, , , gpCode, dataValue
     MsgBox oSset.Count
     If oSset.Count > 0 Then
     Dim i As Long
     Dim objs() As Object
      For i = 0 To oSset.Count - 1
      ReDim Preserve objs(i)
      Set objs(i) = oSset.Item(i)
   Next
Set dbxDoc = New AxDbDocument
Dim idPairs As Variant
Dim copyObj As Variant
copyObj = ThisDrawing.CopyObjects(objs, dbxDoc.ModelSpace, idPairs)
dbxDoc.SaveAs path & Left(dwgname, Len(dwgname) - 4) & "_" & setName & ".dwg"
Next
Set dbxDoc = Nothing
Set layColl = Nothing
Err_Control:
If Err.Number <> 0 Then
MsgBox Err.Description
End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 11
Thank you for your support,
The routine seems to work partially I got an Automation error at point
I insert the library as you suggested, but the routine hangs on such point.
I saw some recently post about some similar error on this forum
http://forums.autodesk.com/t5/Visual-Basic-Customization/AcadApplication-documents-open-execution-er...
Pls could you help me little bit more ?
Thank you
Message 4 of 11
Hallex
I will try to solve it later, seemed to me you've used
another Acad release, mine is A2009,
see you tomorrow,
~'J'~
Message 5 of 11
thank you very much, I'm using Autocad Electric 2013, but I can try with Autocad 2005 if this can help to solve the issue,
Pls feel free to work on that when you have time for this !.
Bye
Message 6 of 11
Hallex
Try this code, I've  changed ObjectDBX declaration within the code,
its working good on my end
Option Explicit
Dim path As String
Dim n
   Next
Dim itm
     setName = CStr(itm)
               While .Count > 0
                    .Item(0).Delete
               Wend
          End With
     MsgBox oSset.Count
     Dim i As Long
   Next
Dim dbxVer As String
Dim acadVer As String
dbxVer = "ObjectDBX.AxDbDocument"
acadVer = Mid(ThisDrawing.GetVariable("AcadVer"), 1, 2)
If Not Int(acadVer) < 16 Then
dbxVer = dbxVer & "." & acadVer
Set dbxDoc = ThisDrawing.Application.GetInterfaceObject(dbxVer)
''Set dbxDoc = New AxDbDocument
Next
Err_Control:
End Sub
~'J'~
Message 7 of 11
Thank you very much for yoour support !! now it's working perfectly.
I should adjust something for the drawing frame perhaps I'll use as xref the main paper frame with drawing information.
Could you explain me better the use of dbx library ? In any case I'll search more on internet docs.
Thank you
Message 8 of 11
Hallex
Glad I could help, but sorry I'm bad teacher for you
better yet to search for ObjectDbx methods in docs,
~'J'~
Message 9 of 11
Pls may I ask you another little question ?.
Is there a way, during the layer scanning to save on the same drawing more layers ?.
I'll try to explain more :
I have the frame of the drawing on layer "0" and the others objects to transform in a single dwg on the layer 001, 002 and so on.
I would like to add to each dwg source from a single layer, also the fram on layer 0 !.
Could you suggest me something ?.
Thank you
Message 10 of 11
Hallex
Let me a try, I'm not sure about how to rewtrite existing layer "0",
that will be added by default in every drawing first
~'J'~
Message 11 of 11
Hallex
Try this code on your machine
Option Explicit
Dim zeroLayer As AcadLayer
Dim path As String
Dim dbxLayer As AcadLayer
Dim n
   Next
Dim itm
     setName = CStr(itm)
               While .Count > 0
                    .Item(0).Delete
               Wend
          End With
      dataValue(0) = 0: dataValue(1) = setName & ",0"
     Dim i As Long
   Next
' copy layer
Dim lPairs As Variant
Dim layObj As Variant
Set zeroLayer = ThisDrawing.Layers.Item("0")
Dim lobj() As Object
ReDim Preserve lobj(0)
Set lobj(0) = zeroLayer
layObj = ThisDrawing.CopyObjects(lobj, dbxDoc.Layers, lPairs)
Set dbxLayer = dbxDoc.Layers.Item("0")
dbxLayer.Linetype = zeroLayer.Linetype
dbxLayer.Lineweight = zeroLayer.Lineweight
dbxLayer.TrueColor = zeroLayer.TrueColor
' copy objects
Next
Err_Control:
End Sub
~'J'~
