Can I delete a vertex from a lwpolyline with VBA?
markc0826
markc0826
when I comand to draw the polyline like: 0,0 -> 10,0 -> 10,15 -> c
I can get the property of closed is True
but if I type : 0,0 -> 10,0 -> 10,15 ->0,0
I get the of closed is False becase 1st point and last point are overlaped.
so how to delete one of endpoints with VBA?
Thanks for advicing..
Hallex
Not sure about if this is what you need but
you can to try this code, found it on forum
Option Explicit
Sub RemoveLast()
 Dim oEnt As AcadEntity
   Dim oPline As AcadLWPolyline
   Dim pickPnt As Variant
   Dim varCoords As Variant
   ThisDrawing.Utility.GetEntity oEnt, pickPnt, "Select a polyline: "
If TypeOf oEnt Is AcadLWPolyline Then
Set oPline = oEnt
   varCoords = oPline.Coordinates
   ReDim Preserve varCoords(UBound(varCoords) - 2)
   oPline.Coordinates = varCoords
End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
markc0826
The point is Redim the coords....
Thank you for your help..^^
Hallex
You're welcome
Cheers 🙂
~'J'~
