MText mixed justification
Hello everyone,
I tried to create Mtext with mixed alignment, but up to now only find the possibility to align the whole text block by following code:
Set InsrtTXT = AcadApp.ActiveDocument.ModelSpace.AddMText(InsrtPnt, 50, TXTString)
InsrtTXT.AttachmentPoint = acAttachmentPointBottomRight
But I want the text like this:
Line 1: Profile-No. 12345_1_Ä2
Line 2:                        RWXXXX
One possibility of course would be to split the text into smaller peaces, but I don't want to do this. Especially because the MText Editor within Autocad allows me exactly to do what I want.
Thanks in advance.
Lars
Ed__Jobe
You need to edit the text string using mtext format codes.
Ed
How to post your code.
Thanks Ed that is obviously a good idea, but up to now I only found parameters to align to Bottom, Center or Top by putting \A+No. in front of the text.
What do you have to use for horizontal alignment?
Ed__Jobe
Format some mtext how you want it. Then select it and look at its Contents property in the Properties palette. This help topic might help some.
If  you're having trouble seeing the format codes, you can switch the editor to Notepad by setting MTEXTED to "notepad".
Specify an Alternate Text Editor
  1. At the Command prompt, enter MTEXTED.
  2. At the prompt do one of the following:
    • Enter the path and name of the executable file for the ASCII text editor that you want to use to create or edit multiline text.
    • Enter Internal to restore the text editor.
Ed
Hello Ed,
thanks you ver much for your help! That was quite helpful answer.
By using "{\P\pql;Text}" you could align single line left. Replacing "l"
through "r" you get IT to the right.
