MText frame
MText frame
MText frame
Hello!
How to show MText frame using vba?
Ed__Jobe
VBA doesn't have an api for that. I don't see how dxf codes handle it. .Net has the MText.ShowBorders method.
Ed
How to post your code.
@Ed__Jobe I think this parameter is controlled by dxf code 90. Is it possible to change the meaning of this code in VBA?
Ed__Jobe
No, VBA and .NET are object oriented programming api's or OOP. They encapsulate codes into objects and properties. So by design, they replace codes with meaningful names. You would need to use LISP to change the dxf codes.
Also, it looks like gc 90 works along with gc 63. You can test with the entlist command I gave you here.
Ed
