MSHFlexGrid
MSHFlexGrid
Message 1 of 8
MSHFlexGrid
Has anybody here ever used the MSHFlexGrid on a heirarchical recordset? I
am having a heck of a time with it. The MS documentation says to use SHAPE
to create the heirarchy, but this gives me an "Invalid SQL statement" error
message. Normally I would just use INNER JOIN, but that does not create a
heirarchy.
The example in the documentation uses SQL server, and I am using an MDB
file. I didn't think that should make a difference, but I can't figure out
what I am doing wrong. My code was just clipped right out of the MS docs
and modified for my program...
Dim strConnect As String
strConnect = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & dbFileName &
";Persist Security Info=False"
' Create a Shape command.
Dim strSh As String
strSh = "SHAPE {SELECT * FROM `dt_field_sample`} AS Samples APPEND ({SELECT
* FROM `dt_results`} AS Results RELATE sys_loc_code TO sys_loc_code) AS
Results"
MyForm.Adodc1.ConnectionString = strConnect
MyForm.Adodc1.RecordSource = strSh
Set MyForm.MSHFlexGrid1.DataSource = MyForm.Adodc1
MyForm.Show
Any suggestions? Please help!
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
Replies (7)
Message 2 of 8
Have you tried Refresh on your Adodc1 object after setting the RecordSource?
R. Robert Bell, MCSE
http://www.acadx.com
"Jon Rizzo" wrote in message
news:6F48401303895D0550DB25D07FE655F5@in.WebX.maYIadrTaRb...
SHAPE
error
| heirarchy.
out
| Dim strSh As String
({SELECT
| Results"
| MyForm.Show
| Jon Rizzo
Message 3 of 8
Actually, the error occurs when I set the RecordSource, so it happens
before I would have the chance to refresh it.
"R. Robert Bell" wrote in message
news:5C7A7F5D76664210760F195D7F83FA6B@in.WebX.maYIadrTaRb...
RecordSource?
I
> SHAPE
> error
a
> | heirarchy.
> out
docs
dbFileName
> | Dim strSh As String
> ({SELECT
> | Results"
> | MyForm.Show
> | Jon Rizzo
Message 4 of 8
Oops, you *did* state that...
news:0643F8B3DE7206ECFF39B9D6EF77173C@in.WebX.maYIadrTaRb...
Message 5 of 8
Have you considered using the DataGrid control instead?
| RecordSource?
recordset?
| I
| > SHAPE
| > error
create
| a
| > | heirarchy.
MDB
figure
| > out
| docs
| dbFileName
| > | Dim strSh As String
| > ({SELECT
AS
| > | Results"
| > | MyForm.Show
| > | Jon Rizzo
Message 6 of 8
The problem is that I need to represent a heirarchy. ie: I have two tables.
For each item in one table, there are several related items in the other.
The only way I know of to show this "grouping" is to use the MSHFlexGrid
control. I don't think that the DataGrid control can't do this.
Is there another way?
Jon
news:1160BF4A549F3F037DC568C88AB6E0C8@in.WebX.maYIadrTaRb...
> | RecordSource?
> recordset?
> | I
use
> | > SHAPE
statement"
> | > error
> create
> | a
> | > | heirarchy.
> MDB
> figure
> | > out
> | docs
> | dbFileName
> | > | Dim strSh As String
> | > ({SELECT
sys_loc_code)
> AS
> | > | Results"
> | > | MyForm.Show
> | > | Jon Rizzo
Message 7 of 8
On Fri, 26 Oct 2001 06:09:39 -0700, "Jon Rizzo" wrote:
» Has anybody here ever used the MSHFlexGrid on a heirarchical recordset?
I haven't but I'll give it a shot.
Try changing this:
» strConnect = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & dbFileName &
» ";Persist Security Info=False"
to something like this:
strConnect = "Provider=MSDataShape;Data Source=" & dbFileName & _
";Persist Security Info=False;Data Provider=Microsoft.Jet.OLEDB.4.0"
Paul Marshall
pmarshal@vulcraft-al.com
Message 8 of 8
You hit the nail right on the head Paul - it works great now!
Thanks for your help.
Jon Rizzo
"Paul Marshall" wrote in message
news:hlejtt86n1cveuo2s3bovf8sb4l0skfunj@4ax.com...
> Try changing this:
dbFileName &
> Paul Marshall
