Memory leak?
Memory leak?
Memory leak?
Has anyone seen memory leaks in VBA?
I inherited a lisp program and converted it to VBA for AutoCAD 2006. The program compares two sets of entities (around 200,000 each), but when I run it, I can see the memory use climb and the program eventually bombs.
As a test, I converted the program to VB 6.0 and when I run it, the memory stays pretty steady, no memory leaks. Of course, the program runs quite a bit slower, so I'd like to get the VBA working.
Has anyone seen similar things? Any solution?
TIA
You can sometimes see this occur if you are not releasing the entity each time you are finished with it:
set entity=nothing
Without seeing the code, I can't help much more than that.
