MDT VBA and collections
Message 1 of 8
In MDT5's VBA I have a collection of objects, say mcad definitions. If I
want to
access one specific item in the collection I currently have to perform a For
Loop until it matches the name of the definition in question. See below.
'Create collection of all definitions in drawing.
Set oMCADComps = CreateArrayOfComponents(oAssMgr.RootDefinition)
'Loop until I find the definition in question.
For j = 0 To oMCADComps.Count - 1
If oMCADComps(j).Definition.Name = "My Special Part" Then
'Found match
Set oPart=oMCADComps(j).Definition.Body
... Do the rest of my thing here (about 30 lines) ...
Next j
Why can't I do the following?
Set oPart=oMCADComps("My Special Part").Definition.Body
In theory it should work, no? Unfortunately it doesn't and I have to
perform the For Loop for at least 10 parts which means cycling through the
oMCADComps (with about 100+ parts) for each part which is taking a LOOOOOONG
time.
Any ideas? TIA
Seth Cohen
Group Leader-Design Department
Mystaire Division
Misonix, Inc.
Replies (7)
Message 2 of 8
If I remember correctly, this is a flaw in the Definitions collection. I
believe you can NOT directly access a definition by it's name, only by
index. (How useful !!). Luckily for me I have not had to refer to a
component definition this way ...so far. There may be an alternative to
iterating the collection and comparing names, however I don't see it right
now.
Jacob Dinardi
"Seth Cohen" wrote in message
news:21F8FC13E0684909C5F5131793729C96@in.WebX.maYIadrTaRb...
> want to
For
> 'Found match
> End If
> Next j
LOOOOOONG
> time.
> Any ideas? TIA
> Seth Cohen
> Mystaire Division
> Misonix, Inc.
Message 3 of 8
Jacob,
If you don't mind, please check out the mcad.mdt5.support ng. I posted the
same question there and I think I may have found a sneaky way around this
frustrating mess.
I basically create another array with just the names, find the name in
question in the array, get the index then use the index back in the
collection. Problem is, how do I get the index from the array without going
through the same mess of For loops? I posted some stuff I tried this
morning but I'm still not 100% there.
If you can help that would be great.
Seth Cohen
Mystaire Division
Misonix, Inc.
"Jacob Dinardi" wrote in message
news:D891D24023EA80E24AAE9A6E6CAA8AC4@in.WebX.maYIadrTaRb...
> now.
> Regards,
> Jacob Dinardi
I
> > want to
> For
below.
> > 'Found match
> > End If
> > Next j
the
> LOOOOOONG
> > time.
> > Any ideas? TIA
> > Seth Cohen
> > Mystaire Division
> > Misonix, Inc.
Message 4 of 8
One thought I have is this:
You could take a one-time hit and create your own collection of component
definitions, when you add the objects to it specify their name as the key.
You should be able to reference this collection instead, using the standard
myCollection("MyItemKey") syntax.
Caveat:
If you create more component definitions you need to update your collection
with the new object. Ugly? Yes. Will it work? I think so!
Jacob
news:C7202801DC5C4E14C8657F693FACA664@in.WebX.maYIadrTaRb...
> Jacob,
the
> frustrating mess.
going
> Thanks
> Seth Cohen
> Mystaire Division
> Misonix, Inc.
right
> > now.
> > Regards,
> > Jacob Dinardi
If
> I
> > > want to
a
> > For
> below.
> > > 'Found match
> > > End If
> > > Next j
> the
> > LOOOOOONG
> > > time.
> > > Any ideas? TIA
> > > Seth Cohen
> > > Mystaire Division
> > > Misonix, Inc.
Message 5 of 8
Jacob,
I already tried to make a variant array just of the defs names. Couldn't
get it to work.
Just tried to a collection of comp defs. Same problem as with any
collection.
There's no way to get the index from a variant if I plug in the name I want
in the array?
I posted 2 sections of code that are a mm away from solving this problem (in
the mcad.mdt5.support ng)
Maybe I'll post another message to this ng about dealing with arrays.
Seth Cohen
Mystaire Division
Misonix, Inc.
news:7F857F707BA7DA8A6F72A30BC3B893BF@in.WebX.maYIadrTaRb...
standard
> Caveat:
collection
> Jacob
> > Jacob,
> the
this
> > frustrating mess.
> going
> > Thanks
> > Seth Cohen
> > Mystaire Division
> > Misonix, Inc.
I
to
> right
> > > now.
> > > Regards,
> > > Jacob Dinardi
> If
> > I
> > > > want to
perform
> a
> > > For
> > below.
Then
> > > > 'Found match
> > > > End If
> > > > Next j
to
through
> > the
> > > LOOOOOONG
> > > > time.
> > > > Any ideas? TIA
> > > > Seth Cohen
> > > > Mystaire Division
> > > > Misonix, Inc.
Message 6 of 8
Seth, I was referring to something like this...
Sub MakeDefsCollection()
Dim oMCAD As McadApplication
Dim oCompDef As McadComponentDefinition
Dim oCompDefs As McadComponentDefinitions
Dim colMyDefs As New Collection
Set oMCAD = Application.GetInterfaceObject("MCAD.Application")
Set oCompDefs = oMCAD.ActiveDocument.AssemblyMgr.Definitions
For Each oCompDef In oCompDefs
colMyDefs.Add oCompDef, oCompDef.Name
Next
colMyDefs("cylinder").Delete
Set colMyDefs = Nothing ' see notes
End Sub
I ran this in a drawing with (2) parts, one called "cylinder" and one called
"cube", it successfully deleted the cylinder definition. Obviously you still
have to use a for...each to initially get the objects into your collection,
however if you need to access it more than once, it will save from running
the loop every time. In this case don't destroy the collection until you aer
done with it.
Like I said though, you need to manually keep it up-to-date, but I think
that would be the case with your solution as well.
Jacob
news:BB4D15ED1C5913BF17A9282DB6963187@in.WebX.maYIadrTaRb...
> Jacob,
> get it to work.
> collection.
want
> in the array?
(in
> Seth Cohen
> Mystaire Division
> Misonix, Inc.
component
key.
> standard
> > Caveat:
> collection
> > Jacob
> > > Jacob,
posted
> > the
> this
> > > frustrating mess.
> > going
> > > Thanks
> > > Seth Cohen
> > > Mystaire Division
> > > Misonix, Inc.
message
collection.
> I
by
> to
> > right
> > > > now.
> > > > Regards,
> > > > Jacob Dinardi
definitions.
> > If
> > > I
> > > > > want to
> perform
> > a
> > > > For
> > > below.
> Then
> > > > > 'Found match
> > > > > End If
> > > > > Next j
> to
> through
> > > the
> > > > LOOOOOONG
> > > > > time.
> > > > > Any ideas? TIA
> > > > > Seth Cohen
> > > > > Mystaire Division
> > > > > Misonix, Inc.
Message 7 of 8
> Jacob,
> get it to work.
> collection.
want
> in the array?
(in
> Seth Cohen
> Mystaire Division
> Misonix, Inc.
component
key.
> standard
> > Caveat:
> collection
> > Jacob
> > > Jacob,
posted
> > the
> this
> > > frustrating mess.
> > going
> > > Thanks
> > > Seth Cohen
> > > Mystaire Division
> > > Misonix, Inc.
message
collection.
> I
by
> to
> > right
> > > > now.
> > > > Regards,
> > > > Jacob Dinardi
definitions.
> > If
> > > I
> > > > > want to
> perform
> > a
> > > > For
> > > below.
> Then
> > > > > 'Found match
> > > > > End If
> > > > > Next j
> to
> through
> > > the
> > > > LOOOOOONG
> > > > > time.
> > > > > Any ideas? TIA
> > > > > Seth Cohen
> > > > > Mystaire Division
> > > > > Misonix, Inc.
Message 8 of 8
YOU ARRRRRE THE MAN!!!
It worked like a charm, and a zillion times faster.
I didn't realize that there was a collection in VBA that was different from
MDT collection. Learn something new everyday.
Thanks again!
Seth Cohen
Mystaire Division
Misonix, Inc.
news:DA1D3CB333105787B8B13DD308B36B12@in.WebX.maYIadrTaRb...
> Next
> End Sub
called
still
collection,
aer
> done with it.
> Jacob
> > Jacob,
Couldn't
> > get it to work.
> > collection.
> want
> > in the array?
> (in
> > Seth Cohen
> > Mystaire Division
> > Misonix, Inc.
> component
> key.
> > standard
> > > Caveat:
> > collection
> > > Jacob
> > > > Jacob,
> posted
> > > the
> > this
> > > > frustrating mess.
in
without
> > > going
this
> > > > Thanks
> > > > Seth Cohen
> > > > Mystaire Division
> > > > Misonix, Inc.
> message
> collection.
> > I
only
> by
a
alternative
> > to
it
> > > right
> > > > > now.
> > > > > Regards,
> > > > > Jacob Dinardi
> definitions.
> > > If
> > > > I
> > > > > > want to
> > perform
> > > a
> > > > > For
See
> > > > below.
> > Then
> > > > > > 'Found match
lines)
> > > > > > End If
> > > > > > Next j
have
> > to
> > through
> > > > the
a
> > > > > LOOOOOONG
> > > > > > time.
> > > > > > Any ideas? TIA
> > > > > > Seth Cohen
> > > > > > Mystaire Division
> > > > > > Misonix, Inc.
