MCAD Pick error
MCAD Pick error
Message 1 of 12
MCAD Pick error
I use the following code in Mechanical Desktop
5:
size=2>'===============================================
    Dim mapp As
McadApplication
    Dim util As
McadUtility
    Set mapp =
ThisDrawing.Application.GetInterfaceObject("Mcad.Application")
Set util = mapp.ActiveDocument.Utility
    Dim Pick As McadPick
    Set Pick =
util.Pick("Select feature", mcFeature)
size=2>'================================================
On the the last line I get the following error
msg.
    Generic failure to execute operation with provided
arguments.
The references are set to the appropriate Mcad
objects and on whatever machine I try this it give me the same
message.
Does anybody know what the problem is?
Wouter
Replies (11)
Message 2 of 12
Wouter
Are you sure you are referencing the right libraries. it should be the 2.0
version of them. Your code below runs without error on my machine.
"Wouter van Eck" wrote in message
news:F5C5EB25CA49CD3AE153E9C88F515238@in.WebX.SaUCah8kaAW...
> Hi,
> I use the following code in Mechanical Desktop 5:
> Dim mapp As McadApplication
> Dim util As McadUtility
> Set mapp =
> Set Pick = util.Pick("Select feature", mcFeature)
> On the the last line I get the following error msg.
> Generic failure to execute operation with provided arguments.
> The references are set to the appropriate Mcad objects and on whatever
machine I try this it give me the same message.
> Wouter
Message 3 of 12
Works for me as well.
Gary
Message 4 of 12
I have a reference to:
- Autodesk BrepAuto 2.0 Type Library
- Autodesk GeAuto 2.0 Type Library
- Autodesk McadAuto 2.0 Type Library
- Autodesk SymBBAuto 2.0 Type Library
Should be enough I would say :-)... nothing is
missing...and I get the objects alright but no luck in getting it to
work..
Any ideas?
> Wouter
be the 2.0
> "Wouter van Eck" <
href="mailto:wouter@flyersoft.com">
size=2>wouter@flyersoft.com
> wrote in
message
href="news:F5C5EB25CA49CD3AE153E9C88F515238@in.WebX.SaUCah8kaAW">
face=Arial
size=2>news:F5C5EB25C...
face=Arial size=2>...
> > Hi,
> > I use the
>     Set mapp =
mcFeature)
> > On
whatever
> Wouter
Message 5 of 12
Wouter
Have you tried isolating just the code you showed in a new module with
nothing else loaded and see if it works? Only other thing I can think of is
I am running SP2 for MDT5.
news:1A62CD219E1C9CA96759BD575913D7CD@in.WebX.SaUCah8kaAW...
Message 6 of 12
I did that too... it's running in a new drawing, with a new empty module....
with SP2 aswell... both machines give the same problem...
"Kent Keller" wrote in message
news:A78B53190E23DA6E4991688464E47CE8@in.WebX.SaUCah8kaAW...
> Wouter
is
Message 7 of 12
First of all your code sinppet runs fine on my
machine.
You may try the initialization with
Set mapp =
ThisDrawing.Application.GetInterfaceObject("Mcad.Application.2")
That should make sure that you get the right
interface for MDT5.
Try to run mcadautoreg.exe, which is in the MDT
directory. This should do the registry entries again. Maybe something went
wrong. Do you have admin writes on your machine ?
Hope ths helps.
Christian
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
5:
    Dim mapp As
McadApplication
    Dim util As
McadUtility
    Set mapp =
    Set Pick =
msg.
arguments.
message.
is?
Wouter
Message 8 of 12
Christian
Thanks for the tips. I've been having some sort of conflict between newer
and older programs using the two different models. I'll bet your suggestions
are the answer to the problem.
Gary
Message 9 of 12
I just found out that when I start 'Autocad Mechanical 2000i Power Pack'
then it doesn't work and a lot of other functions don't either.
It works fine with AutoCAD Mechanical Desktop...
Wouter
"Gary McMaster" wrote in message
news:81A2B180FF34465890D102EF030FF737@in.WebX.SaUCah8kaAW...
> Christian
suggestions
> Gary
Message 10 of 12
That's another good point. I didn't have power pack with MDT4 and have never
tried MDT5 without it.
None of my VBA stuff will run in MDT4 anymore since installing MDT5, but it
still runs fine in MDT5.
Gary
Message 11 of 12
That's because AutoCAD Mechanical and Mechanical Desktop are two
entirely separate products.
http://www.acadx.com
All use of the contents of this article is subject to the
terms and conditions at http://www.acadx.com/csc.htm
news:64B26D437356584DD429D3898D321C3D@in.WebX.SaUCah8kaAW...
Pack'
> Wouter
Message 12 of 12
The MDT4 code is untouched and still referencing the McadAuto 1.0 and the
other 1.0 models. It runs on any MDT4 machine until MDT5 is installed. It
continues running in MDT5 even though still referencing the MDT4 model. Just
seems a little strange.
Gary
