MANTAIN THE GROUPS AFTER INSERT BLOCK
hello.
i use acad2006
I have a part named part1.dwg that contain some enities that are grouped in
the group test now i want
make a insertblock and explode it but i want mantain the previos group.
If i make this operation by line command without automatik explode and that
explode by command all is ok.
But if i make the same operation by program don't work.
First version:
Try
p1(0) = 0
p1(1) = 0
p1(2) = 0
BlockRef = AcInt.AcadDoc.ModelSpace.InsertBlock(p1, "c:\part1.dwg"1, 1, 0.0)
Block = AcInt.AcadDoc.Blocks.Item(BlockRef.Name)
BlockRef.Explode()
BlockRef.Delete()
Block.Delete()
Catch ex As Exception
MessageBox.Show(ex.Message)
Finally
AcInt.AcadApp.ZoomExtents()
BlockRef = Nothing
Block = Nothing
End Try
second version
This version have work until acad2005
now don't work
Try
p1(0) = 0
p1(1) = 0
p1(2) = 0
BlockRef = AcInt.AcadDoc.ModelSpace.InsertBlock(p1, "c:\part1.dwg",1, 1,
0.0)
J = -1
ReDim CollObj(Block.Count - 1)
For Each Obj In Block
J += 1
CollObj(J) = Obj
Next Obj
RetVal = AcInt.AcadDoc.CopyObjects(CollObj, AcInt.AcadDoc.ModelSpace, )
For J = 0 To UBound(RetVal)
Obj = RetVal(J)
Obj.ScaleEntity(p1, scalex)
Obj.Move(p1, insertionpnt)
Obj.Rotate(insertionpnt, degrad(rot))
Next
BlockRef.Delete()
Block.Delete()
Finally
BlockRef = Nothing
Block = Nothing
RetVal = Nothing
End Try
is possible changed the ownerid of the enities in the blockdefinition and
put modelspace?
Now both the solution dont work.
Some help?
Not sure what you are asking. Does the blockref that you are inserting contain nested blocks or actually a group?
actualy contain a group.
after the insert and explode by one of the two method i dont find never the
group.
If i make by line command insert block and after the insert make the command
explode i find my original group.
Thank's GPaolo
ha scritto nel messaggio news:5022852@discussion.autodesk.com...
I thought Jeff Mishler would answer this, any way below is adapted from his copy function. Since you explode the block I thought you might rather just copy the objects instead. If you add a group to a block then explode the blockref (in cad) it kills the group, but like you said if you insert the block from another drawing and explode it, it stays as a group. Another mystery. I don't know enough about lisp and reactors to figure that out but in VBA there seems to be no info available to tell if an entity is part of a group.
Sub GetBlockItems(strDwgName As String, Optional Pt As Variant)
'Requires a reference to Autocad/ObjectDbx Common library
Dim dbxDoc As AxDbDocument
If Int(Left(ThisDrawing.GetVariable("ACADVER"), 2)) = 15 Then
Set dbxDoc = GetInterfaceObject("ObjectDBX.AxDbDocument")
Else
Set dbxDoc = GetInterfaceObject("ObjectDBX.AxDbDocument.16")
End If
dbxDoc.Open (strDwgName)
Dim Copyobjs As Variant
Dim idpairs As Variant
Dim arrObject() As AcadObject
Dim Ct As Integer, i As Integer
Dim oMod As AcadBlock
Set oMod = dbxDoc.ModelSpace
Ct = oMod.Count - 1
ReDim arrObject(Ct)
For i = 0 To Ct
Set arrObject(i) = oMod(i)
Next i
Copyobjs = dbxDoc.CopyObjects(arrObject, ThisDrawing.ModelSpace, idpairs)
Dim Ent As AcadEntity
Dim oGroup As AcadGroup, oGroups As AcadGroups
Dim NewGroup As AcadGroup
Dim GroupObj(0) As AcadObject
Set oGroups = dbxDoc.Groups
For Each oGroup In oGroups
If InStr(1, oGroup.Name, "*", vbTextCompare) <> 0 Then GoTo skipGroup
If oGroup.Count = 0 Then GoTo skipGroup
Set NewGroup = ThisDrawing.Groups.Add(oGroup.Name)
For Each Ent In oGroup
For i = 0 To UBound(idpairs)
If idpairs(i).key = Ent.ObjectID Then
Set GroupObj(0) = ThisDrawing.ObjectIdToObject(idpairs(i).value)
NewGroup.AppendItems GroupObj
End If
Next i
Next Ent
skipGroup:
Next oGroup
Set dbxDoc = Nothing
If Not IsMissing(Pt) Then
Dim Origin(2) As Double
For i = 0 To UBound(Copyobjs)
Set Ent = Copyobjs(i)
Ent.Move Origin, Pt
Next i
End If
End Sub
Ok.
You have resolve my problem.
Many thank's
GPaolo
ha scritto nel messaggio news:5022963@discussion.autodesk.com...
group.
Else
End If
Ct = oMod.Count - 1
ReDim arrObject(Ct)
For i = 0 To Ct
Next i
idpairs)
skipGroup
Set GroupObj(0) =
End If
Next i
Next Ent
skipGroup:
Next oGroup
Ent.Move Origin, Pt
Next i
End If
End Sub
