making a block
making a block
making a block
Hello Group:
I had this code working in another routine. It makes a block
now it refuses to run, and throws an error 'type mismatch'
I've tried everything, what am I doing wrong here? Thanks in
advance
this is for release14, vba
thanks
If blkexist = False Then
Dim nwblk As AcadBlock
Dim tag1, tag2, tag3, tag4, def1, def2, def3, def4 As String
Dim blkinpnt1(0 To 2) As Double
blkinpnt1(0) = 0#: blkinpnt1(1) = 0#: blkinpnt1(2) = 0#
Dim blkinpnt2(0 To 2) As Double
blkinpnt2(0) = 0#: blkinpnt2(1) = 1#: blkinpnt2(2) = 0#
Dim blkinpnt3(0 To 2) As Double
blkinpnt3(0) = 0.0347222: blkinpnt3(1) = 1#: blkinpnt3(2) = 0#
Dim blkinpnt4(0 To 2) As Double
blkinpnt4(0) = 0.0347222: blkinpnt4(1) = 0#: blkinpnt4(2) = 0#
Set nwblk = ThisDrawing.Blocks.Add(blkinpnt1, "door")
Set nwblk = nwblk.AddLine(blkinpnt1, blkinpnt2)
Set nwblk = nwblk.AddLine(blkinpnt2, blkinpnt3)
Set nwblk = nwblk.AddLine(blkinpnt3, blkinpnt4)
Set nwblk = nwblk.AddLine(blkinpnt4, blkinpnt1)
Set nwblk = nwblk.AddArc(blkinpnt1, 1#, 0, 1.570796)
The error is in these lines :
The AddLine method returns a Line object and you are trying to assign it
to a BlockObject.
Solution :
dim MyLine as AcadLine
dim MyArc as AcadArc
Set MyLine = nwblk.AddLine(blkinpnt1, blkinpnt2)
Set MyArc = nwblk.AddArc(....etc)
Arno van Eeuwen
Andy wrote:
> Hello Group:
> advance
> thanks
> End If
Hi Andy,
I am a novice at this myself, but the literature I have read
would suggest that the code should look something like this:-
Dim objLine As AcadLine
Dim objArc As AcadArc
Set objLine = nwblk.AddLine(blkinpnt1, blkinpnt2)
Set objLine = nwblk.AddLine(blkinpnt2, blkinpnt3)
Set objLine = nwblk.AddLine(blkinpnt3, blkinpnt4)
Set objLine = nwblk.AddLine(blkinpnt4, blkinpnt1)
Set objArc = nwblk.AddArc(blkinpnt1, 1#, 0, 1.570796)
Let me know if it works.
Cheers, John.
Andy wrote in message <387655E4.4B86277@bellsouth.net>...
>Hello Group:
>advance
>thanks
>End If
You can ignore the return values from any of the Add methods if you do not
need to reference them after their creation. Makes for a lot fewer
variables.
So this:
Becomes this:
nwblk.AddLine blkinpnt2, blkinpnt3
