Loop, Yes/No
Loop, Yes/No
Loop, Yes/No
I do not understand why following code does not work. Could someone give me a solution to loop an action until a "No" or "N" is input. Thanks in advance.
Dim KeepGoing As Boolean, Answer As String
KeepGoing = True
Dim kWordList As String
kWordList = "Yes No"
ThisDrawing.Utility.InitializeUserInput 1, kWordList
Do While KeepGoing
action code
Answer = ThisDrawing.Utility.GetKeyword("Continue ...(yes)/(No): ")
If Answer = "No" Then KeepGoing = False
Loop
Place the InitializeUserInput in the Loop. It is reset each time an input is
entered.
wrote in message news:5310253@discussion.autodesk.com...
advance.
Did not work either. Any ideas?
It works now. thanks a lot.
