Looking to translate X,Y coordinate system to A-H,1-10 grid.
Dealing only with 2D here (X,Y). I have dwgs that contain a grid location system of A through H on the left vertical axis and 1 through 10 on the top horizontal axis. So, for an E size dwg of 48"x36", I would like to list the location of all the objects on the sheet (ie Obj 1 = B4, Obj 2 = G7, Obj 3= D9, etc).
Any suggestions are sincerely appreciated.
grobnik
Hi @Anonymous ,
I guess you have to check the objects insertion point and on the other side making a cross "table" which convert the object coordinate in "row, column" style.
For example  if the object insertion point will be in a range of coords which will be the portion of sheet length or sheet width you can apply the number of correspondent row/column.
I guess it's a large code to do, as alternative you can create a function.
But I'm seeing some issue into this procedure: if the object falls between two rows or two column how to assign to object the right row or column ? do you have a "with-in" range ?.
It IS possible to have an object located on one or more division lines. Since this project does not require precision, I suppose the lesser of the grid locales is okay to use. For example, if an object is located on the cross-hairs of B3, B4, C3, and C4, it is acceptable to mark the object as located in B3.
Anyone ever seen functions similar to this? If so, got a snippet or link?
