Looking for a way to find these points of an arc within a 2d polyline
I need help finding a way to retrieve these points of an arc within a 2d polyline using VBA. Any help or suggestions would be greatly appreciated.
MakCADD
extract the points of the segments of line
that is if bulge is 0 ----pline.getbulge(segmentIndex)=0
then create lines from these segments
and find intersection points  line1.intersectwith(line2,acextendboth)
then delete these temporary lines
MakCADD
Sub IP_Points()
Dim Pline As AcadLWPolyline
Dim Blge
Dim Lin() As AcadLine
Dim stpt(0 To 2) As Double
Dim enPt(0 To 2) As Double
Dim pT1
Dim pT2
Dim P As Integer
P = 0
Set Pline = ThisDrawing.ModelSpace.Item(0)
'Find straight line segments-----------
For I = 0 To ((UBound(Pline.Coordinates) - 1) / 2) - 1
Blge = Pline.GetBulge(I)
If Blge = 0 Then
ReDim Preserve Lin(P) As AcadLine
pT1 = Pline.Coordinate(I)
pT2 = Pline.Coordinate(I + 1)
For J = 0 To 1
stpt(J) = pT1(J)
enPt(J) = pT2(J)
Next J
stpt(2) = Pline.Elevation
enPt(2) = Pline.Elevation
Set Lin(P) = ThisDrawing.ModelSpace.AddLine(stpt, enPt)
P = P + 1
End If
Next '-------------------------------------------------
'Find Point of Intersection
Dim IntPt
For l = 0 To UBound(Lin) - 1
IntPt = Lin(l).IntersectWith(Lin(l + 1), acExtendBoth)
ThisDrawing.ModelSpace.AddCircle IntPt, 1
Next l
'Delete temporary lines
Lin(l).Delete
Next l
End Sub
