Loading in non-English text to AutoCAD via VBA?
aaron.wrightCPM6Y
Message 1 of 14
aaron.wrightCPM6Y
I'm scanning a CSV document which contains both english and russian text. If I copy the russian text directory into autoCAD, it shows up fine.
However, when reading from the CSV in VBA, the Russian text is inaccurate. If I try displaying the Russian via a Message Box for example, or add it in the drawing, it just shows up as random symbols. I imagine because of something to do with the type of encoding when reading the file in. My code currently looks like the below.
    Open FilePath For Input As #1
        Do Until EOF(1)
            Line Input #1, LineFromFile
            LineItems = Split(LineFromFile, ",")
            mykey = LCase(LineItems(0))
            myvalue = LineItems(1)
            translator_dict.add key:=mykey, Item:=myvalue
        Loop
    Close #1
I am just wondering if there's a way for me to load in the Russian correctly.
Replies (13)
Message 2 of 14
Ed__Jobe
That INPUT function is as old as DOS. It's not going to do what you want. I would read that file using Excel too.
Ed
How to post your code.
Message 3 of 14
aaron.wrightCPM6Y
Thanks. I'll give this a try, although I did notice when opening the CSV in Excel, Excel was also showing the incorrect text.
Message 4 of 14
Ed__Jobe
Post a sample of the csv.
Ed
Message 5 of 14
aaron.wrightCPM6Y
Sure. I've just attached a small example.
Message 6 of 14
aaron.wrightCPM6Y
I managed to get it to open correctly in Excel just using the import functionality rather than opening the file directly in Excel.
However, still struggling to refactor my code so that it will display the Russian correctly in VBA. I feel like I need to open the CSV with UTF-8 encoding but can't find a solution for this.
Message 7 of 14
Ed__Jobe
Try this for an idea.
Public Function GetXL() As Application
    On Error Resume Next
    Dim xlApp As Application
    Set xlApp = GetObject(, "Excel.Application")
    If xlApp Is Nothing Then
        Set xlApp = CreateObject("Excel.Application")
    Set GetXL = xlApp
End Function
Sub RussianTest()
    Dim xl As Application
    Set xl = GetXL()
    Dim wb As Workbook
    Dim strText As String
    Dim iPt(0 To 2) As Double
    iPt(0) = 1
    iPt(1) = 1
    iPt(2) = 0
    Set wb = xl.Workbooks.Open("C:\path\test-russian.xlsx")
    strText = wb.Sheets("Sheet1").Cells(1, 2).Value()
    ThisDrawing.PaperSpace.AddText strText, iPt, 1#
    Set wb = Nothing
    Set xl = Nothing
End Sub
Ed
Message 8 of 14
aaron.wrightCPM6Y
Perfect thank you! I had to refactor a bit, but this looks to be doing what I want it to do.
Message 9 of 14
aaron.wrightCPM6Y
EDIT: Tried XL.Quit but it closes all instances of Excel
One last thing, I've tried closing the Excel file once the script is finished. However, after running the script I get an error that the file is being used by another program. To fix it, I need to close Excel via Task Manager. Is there anything obviously wrong with my function below? I can submit a new question for this.
I would assume that the Set XL = Nothing at the bottom would have sorted it.
Public Function AddToDictionary(FilePath As String, SheetName As String)
    ' Create Excel Object
    Dim XL As Excel.Application
    Set XL = GetObject(, "Excel.Application")
    If XL Is Nothing Then
        Set XL = CreateObject("Excel.Application")
    Dim wb As Workbook
    Dim i As Long
    Set wb = XL.Workbooks.Open(FilePath)
    Set mysheet = wb.Sheets(SheetName)
    ' Create Dictionary
    Set translator_dict = CreateObject("Scripting.Dictionary")
    ' Number of rows in first column of sheet
    NumRows = mysheet.Range("A2", mysheet.Range("A2").End(xlDown)).Rows.Count
    ' Append sheet data to dictionary
    For i = 1 To NumRows + 1
        If Not IsEmpty(mysheet.Cells(i, 1).Value) Then
            translator_dict.add key:=LCase(mysheet.Cells(i, 1).Value()), Item:=mysheet.Cells(i, 2).Value()
    Next i
    Set mysheet = Nothing
    Set wb = Nothing
    Set XL = Nothing
    Set AddToDictionary = translator_dict
End Function
Message 10 of 14
Ed__Jobe
    Dim wb As Workbook
    Dim i As Long
    ' Create Dictionary
    Next i
    wb.Close          'Added
    Set wb = Nothing
    xl.Quit           'Added
    Set XL = Nothing
End Function
See my changes above. If you add the line to quit xl, you can add logic to check the Workbooks collection first. If there are still workbooks open, the Count will be greater than 0. So if the Count is 0, you can Quit xl.
Also, I highly recommend that you leave the xl object creation in its own sub. A lot of people assume that On Error Resume Next only applies to the next line. But it stays in effect during the scope of the sub. IOW, it will suppress all errors in your sub unless you reset it. Search VBA help for "On Error Statement"  topic on how to do that. The preferred method is to containerize your code. Keep tasks separate. Besides, there may come a time when you want to use that function for another sub.
Also, you didn't Dim the NumRows variable. VBA will handle it for you at runtime, but it will always be cast as a Variant. If you include Option Explicit statement at the top of your module, the IDE will remind you that you didn't dim a var. If you go Tools>Options>Editor tab and check "Require Variable Declaration", it will add the Option Explicit statement for you when you create a new module.
Ed
Message 11 of 14
aaron.wrightCPM6Y
Perfect thank you. I shall take a look.
I'm not really a VBA programmer, so I've never quite understood why 'Dim' and 'Set' are used to declare variables or objects. If something is of type variant, is does it just take up more memory?
And thanks for mentioning the Option Explicit statement idea. I will add that in - as well split XL creation into a different sub.
Message 12 of 14
Ed__Jobe
Dim dimensions a variable, i.e. allocates memory...and yes, a Variant takes up the most memory. Set does not declare a variable, it assigns to the memory location created by Dim.
A variable is a memory location. Think of it as a bucket for storing things. There are different types of memory locations. Some intrinsic data types like single, double and string don't need special handling. But object types of variables do and so require the Set statement.
Ed
Message 13 of 14
aaron.wrightCPM6Y
Thank you. That makes more sense now.
I'll also try split my code up so the XL creation is separate. However most of what I try results in numerous errors which I'm finding difficult to resolve. For what I've done below, does it make sense to try split this function into two separate functions?
    Dim wb As Workbook
    Dim i As Long
    ' Create Dictionary
    Next i
    wb.Close
    Set wb = Nothing
    Set XL = Nothing
End Function
Message 14 of 14
aaron.wrightCPM6Y
Forget this. I found my mistake, and have now divided it up into separate functions.
