list of all object for one layer - VBA
what's the best way to get list (AcadSelectionSet) of all objects presented
in one layer using VBA
thanks a lot
Try this out...........
Sub allonspecifiedlayer()
' This routine allows the user to select everything on screen. Then it
goes through all
' of the objects one by one and puts them in a list along with the layer
name.
' Need to create a form called objectsfrm and add a listbox called
listbox1 to form.
'dimension these variables
Dim ssetObj As AcadSelectionSet
Dim sset As AcadSelectionSets
Dim acadobj As AcadObject
Dim objname As String
Dim objlayer As String
Dim I As Integer
Dim corner1(0 To 2) As Double
Dim corner2(0 To 2) As Double
corner1(0) = -10000000000#: corner1(1) = -10000000000#: corner1(2) = 0
corner2(0) = 10000000000#: corner2(1) = 10000000000#: corner2(2) = 0
I = 0
objectsfrm.ListBox1.ColumnCount = 3
Set sset = ThisDrawing.SelectionSets
For Each ssetObj In sset
If UCase(ssetObj.Name) = "TEST" Then
sset.Item("TEST").Delete
Exit For
Next
Set ssetObj = ThisDrawing.SelectionSets.Add("TEST")
' Add all the objects to the selection set
ssetObj.Select acSelectionSetAll
For Each acadobj In ssetObj
'Filter out everything on specified layer.
If acadobj.Layer = "L004" Then
objname = acadobj.ObjectName
objlayer = acadobj.Layer
objectsfrm.ListBox1.AddItem objname
objectsfrm.ListBox1.List(I, 1) = objlayer
I = I + 1
Next acadobj
'Show form
objectsfrm.Show
End Sub
Martin
"Jaroslav Adamec" wrote in message
news:F39C362B75A13827D6A499A4D5902E44@in.WebX.maYIadrTaRb...
presented
> thanks a lot
> presented in one layer using VBA
The answer is a filtered selection set:
Dim ss As AcadSelectionSet, fType, fData
Set ss = CreateSelectionSet()
Call BuildFilter(fType, fData, 0, "SomeLayerName")
ss.Select acSelectionSetAll, , , fType, fData
Links:
CreateSelectionSet: http://code.acadx.com/visualbasic/010.htm
BuildFilter: http://code.acadx.com/visualbasic/004.htm
To learn more about filtered selection sets, first visit the VBA online
help for selection set objects then view the DXF Reference in the
VisualLISP online help.
"It's more important that you know how to find the answer than to have
the answer." - Me
Hey there,
I tried your code but it is built on two other subs or functions that are not shown in the post... so I tried the link where they were supposed to be hosted, but the links have expired in the 15 years since your post.
Darn it.
Ed__Jobe
Frank hasn't been around for years, but the subs are simple. Here are my versions.
Public Function AddSelectionSet(SetName As String) As AcadSelectionSet
' This routine does the error trapping neccessary for when you want to create a
' selectin set. It takes the proposed name and either adds it to the selectionsets
' collection or sets it.
    On Error Resume Next
    Set AddSelectionSet = ThisDrawing.SelectionSets.Add(SetName)
    If Err.Number <> 0 Then
        Set AddSelectionSet = ThisDrawing.SelectionSets.Item(SetName)
        AddSelectionSet.Clear
End Function
Public Sub BuildFilter(typeArray As Variant, dataArray As Variant, ParamArray gCodes())
'Purpose
'Fills a pair of variants with arrays for use as a selection set filter
'Arguments
'Two variants (not variant arrays) and an unlimited number of group code / value pairs
'Example
'BuildFilter fType, fData, 0, "LINE", 7, "WALLS"
    Dim fType() As Integer, fData()
    Dim index As Long, i As Long
    index = LBound(gCodes) - 1
    For i = LBound(gCodes) To UBound(gCodes) Step 2
        index = index + 1
        ReDim Preserve fType(0 To index)
        ReDim Preserve fData(0 To index)
        fType(index) = CInt(gCodes(i))
        fData(index) = gCodes(i + 1)
    Next
    typeArray = fType: dataArray = fData
End Sub
Ed
How to post your code.
