Hi @Anonymous ,
here below a sample code, that could be fixed more but it's a starting point, that should help you with your issue
Public Sub lista_poly()
    Dim Myapp As Object
    Dim MyDwg As AcadDocument
    Dim Obj As AcadObject
    Dim Ent As AcadEntity
    Dim text As AcadText
    Dim w As Worksheet
    Dim Ppos() As Double
    Dim line As AcadLine
    Dim pontos As Double
    Dim MySset As AcadSelectionSet
    Dim FilterType(4) As Integer
    Dim FilterData(4) As Variant
    Dim P1(0 To 2) As Double
    Dim P2(0 To 2) As Double
    R = 2
    Set Myapp = GetObject(, "Autocad.application")
    Set MyDwg = Myapp.ActiveDocument
    Sheets(1).Range("B1") = "X"
    Sheets(1).Range("C1") = "Y"
    For Each Obj In MyDwg.ModelSpace
        If TypeOf Obj Is AcadLWPolyline Then
            Line_Pos = Obj.Coordinates
            For i = 0 To UBound(Line_Pos) Step 2
               Sheets(1).Range("B" & R) = Line_Pos(i)
               Sheets(1).Range("C" & R) = Line_Pos(i + 1)
               R = R + 1
            Next
          '  GetMaxNumber (Line_Pos)
        P1(0) = Line_Pos(0)
        P1(1) = Line_Pos(1)
        P1(2) = 0
        P2(0) = UBound(Line_Pos) - 1
        P2(1) = UBound(Line_Pos)
        P2(2) = 0
        On Error Resume Next
        Set MySset = MyDwg.SelectionSets.Add("MySel")
        If Err.Number <> 0 Then
            MyDwg.SelectionSets.Item("MySel").Delete
        End If
        FilterType(0) = -4
        FilterData(0) = "<or"
        FilterType(1) = 0
        FilterData(1) = "TEXT"
        FilterType(2) = 0
        FilterData(2) = "MTEXT"
        FilterType(3) = 0
        FilterData(3) = "DIMENSION"
        FilterType(4) = -4
        FilterData(4) = "or>"
        'MySset.Select acSelectionSetWindow, P2, P1, FilterType, FilterData
        MySset.Select acSelectionSetAll, , , FilterType, FilterData
        If MySset.Count >= 1 Then
            For a = 0 To MySset.Count
                Select Case MySset.Item(a).ObjectName
                Case "AcDbText"
                    Sheets(1).Range("A" & R) = MySset.Item(a).TextString
                Case "AcDbRotatedDimension"
                    Debug.Print "DIMENSION ROTATED"
                    Sheets(1).Range("D" & R) = MySset.Item(a).Measurement
                    R = R + 1
                End Select
            Next
        End If
        End If
    Next
    End Sub
It's based upon a polyline, see attached drawing.
The part of code 'MySset.Select acSelectionSetWindow, P2, P1, FilterType, FilterData, could be used for refine text search related inside the founded polyline.
I mean, that whenever you find a polyline object, and you are retrieving the  coordinates, you can with a function find the max and min value inside the vertex coordinates array, based upon that value in the coordinates array are stored by X, following Y value for each vertex.
So if you search TEXT, and DIMENSION with Selection Set around the MIN and MAX vertex coordinates value, you will be sure to catch the text and dimensions of found polyline on drawing no more.
In the next days I'll try to develop this part too and make some test, I'll keep you informed.
I hope above could help you more.
See attached sample xlsm (with macro inside) and drawing with polyline.
