OK thanks, excellent, I was making it too hard on myself and must have
misread something.
All I need is: DIMBLK1 _OPEN90
Mark Propst wrote:
>are you on 2004?
>I don't know about that, but the setvar still works if what you're doing is
>creating a dimension style, as opposed to overriding the style for a
>particular dimension, I thought that's what you were trying to do.
>"Paul Furman"
wrote in message
>news:3D98C52F6502ABB77073001B4218C372@in.WebX.maYIadrTaRb...
>>Thanks for the reply Mark!
>>The block type arrowheads work that way but apparently the built-in
>>arrow styles are set with an ObjectID Property (whatever that is?) which
>>ovverrides dimblk. See below for the help file explanation, which sounds
>>like gibberish to my ears.
>>Mark Propst wrote:
>>>ThisDrawing.SetVariable "dimblk", "_archtick"
>>>"Paul Furman" wrote in message
>>>news:ADB7F6BA73077D5243985A5B39D90D7D@in.WebX.maYIadrTaRb...
>>>>I'm looking at something perhaps related. Trying to change the "running"
>>>>arrowhead style through vb or lisp. See my post below:
>>>>Setting Property (for a clueless lisper)
>>Arrowhead1Type Property
>>Specifies the type of arrowhead for the first end of the dimension line.
>>Signature
>>object.Arrowhead1Type
>>object Dim3PointAngular, DimAligned, DimAngular, DimDiametric,
>DimRotated
>>The object or objects this property applies to.
>>Arrowhead1Type acDimArrowheadType enum; read-write
>>acArrowDefault
>>acArrowDot
>>acArrowDotSmall
>>acArrowDotBlank
>>...etc...
>>acArrowUserDefined Read-only
>>System variables
>>This property overrides the value of the DIMBLK1 system variable for the
>>given dimension.
>>Remarks
>>The initial value for this property is acArrowDefault
>>When you use the Arrowhead1Block property to specify a block to use as a
>>custom arrowhead, this property will be set to acArrowUserDefined.
Paul Furman
http://www.edgehill.net
san francisco native plants
(415) 722-6037
