lineair dimension
lineair dimension
Message 1 of 10
lineair dimension
I need some help again.
I want to place some lineair diminsions.
I've try'd Aligned dimension like this:
dim dimObj as AcadDimAligned
It works, but how to place lineair dim?
Is there something like AcaddimLinear????
thx for help,
Sa
Replies (9)
Message 2 of 10
Sabrina,
Attached is an example I think should help you.
Joe
Message 3 of 10
Hi Joe,
Since you answered her question "is it possible to
create a Linear child style dimension"(my paraphrase) with a sub that creates
aligned dimensions, I'm taking it as you're saying there is no linear option for
vba?
your sub creates a dimension in the parent style
eg: Standard
the Dimlinear command in the linear child
style   eg: Standard:linear
as seen in the properties window.
I see no AddDimLinear in the help
files.
So, just to confirm, in lisp or acad command I can
create a linear dimension
In vb(a) I cannot create a linear
dimension
Is that correct?
Mark
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Sabrina,
Joe
Message 4 of 10
I'm looking at something perhaps related. Trying to change the "running"
arrowhead style through vb or lisp. See my post below:
Setting Property (for a clueless lisper)
Mark Propst wrote:
> Hi Joe,
> Since you answered her question "is it possible to create a Linear
> child style dimension"(my paraphrase) with a sub that creates aligned
> for vba?
> your sub creates a dimension in the parent style eg: Standard
> the Dimlinear command in the linear child style eg: Standard:linear
> I see no AddDimLinear in the help files.
> So, just to confirm, in lisp or acad command I can create a linear
> dimension
> In vb(a) I cannot create a linear dimension
> Is that correct?
> Thanks
> Mark
> "joesu" >
> wrote in message news:f1727f3.0@WebX.maYIadrTaRb...
> Sabrina,
> Joe
Message 5 of 10
ThisDrawing.SetVariable "dimblk", "_archtick"
"Paul Furman" wrote in message
news:ADB7F6BA73077D5243985A5B39D90D7D@in.WebX.maYIadrTaRb...
Message 6 of 10
Thanks for the reply Mark!
The block type arrowheads work that way but apparently the built-in
arrow styles are set with an ObjectID Property (whatever that is?) which
ovverrides dimblk. See below for the help file explanation, which sounds
like gibberish to my ears.
Arrowhead1Type Property
Specifies the type of arrowhead for the first end of the dimension line.
Signature
object.Arrowhead1Type
object Dim3PointAngular, DimAligned, DimAngular, DimDiametric, DimRotated
The object or objects this property applies to.
Arrowhead1Type acDimArrowheadType enum; read-write
acArrowDefault
acArrowDot
acArrowDotSmall
acArrowDotBlank
...etc...
acArrowUserDefined Read-only
System variables
This property overrides the value of the DIMBLK1 system variable for the
given dimension.
Remarks
The initial value for this property is acArrowDefault
When you use the Arrowhead1Block property to specify a block to use as a
custom arrowhead, this property will be set to acArrowUserDefined.
Message 7 of 10
are you on 2004?
I don't know about that, but the setvar still works if what you're doing is
creating a dimension style, as opposed to overriding the style for a
particular dimension, I thought that's what you were trying to do.
news:3D98C52F6502ABB77073001B4218C372@in.WebX.maYIadrTaRb...
> Signature
DimRotated
> acArrowDefault
> acArrowDot
> acArrowDotSmall
> acArrowDotBlank
> ...etc...
> System variables
> given dimension.
> Remarks
Message 8 of 10
OK thanks, excellent, I was making it too hard on myself and must have
misread something.
All I need is: DIMBLK1 _OPEN90
Mark Propst wrote:
>are you on 2004?
>>Signature
>DimRotated
>>acArrowDefault
>>acArrowDot
>>acArrowDotSmall
>>acArrowDotBlank
>>...etc...
>>System variables
>>given dimension.
>>Remarks
Paul Furman
http://www.edgehill.net
san francisco native plants
(415) 722-6037
Message 9 of 10
actually I think all you need is Dimblk (if you want both arrows to be the
same)
(if they are different, then dimblk1 and 2 do that)
(i think)
news:DE6433AC2F66130CA97A45C505EF6D03@in.WebX.maYIadrTaRb...
> misread something.
Message 10 of 10
That's correct, thanks.
>same)
>(i think)
>>misread something.
