Leader - 2 Points?
Leader - 2 Points?
Leader - 2 Points?
Is there a way to create a leader with 2 points instead of three? I just
want a one legged leader.. ------------->
Thanks in advance,
Nate
Yes. If you're using the LEADER command, then you simply input two points,
then echo 2 'Enter's and then 'N' or 'None' where it prompts for text. I do
mine with LISP, so no, don't have the VBA code for doing this.
Voila! 2 pt leader.
"Nate" wrote in message
news:EDDE046DBA2ECC27C04A4F12E2224294@in.WebX.maYIadrTaRb...
> Thanks in advance,
> Nate
I have my VBA leaders setup similar to what Jason does in LISP.
In VBA I have
ThisDrawing.SendCommand "leader" & vbCr & varStartPoint(0) & "," &
varStartPoint(1) & vbCr & varEndPoint(0) & "," & varEndPoint(1) & vbCr &
vbCr & strMtext & vbCr
Probably is not the most efficient way.
HTH
Bruce
> Thanks in advance,
> Nate
Here's how to do it the VBA way.
Joe
Dim Annotation As AcadEntity
Dim Points(0 To 5) As Double
Dim StartPoint As Variant
Dim EndPoint As Variant
Dim LeaderType As Integer
Dim Counter As Integer
LeaderType = acLineWithArrow
StartPoint = ThisDrawing.Utility.GetPoint(, "Select leader start point: ")
EndPoint = ThisDrawing.Utility.GetPoint(StartPoint, "Select leader end point: ")
For Counter = 0 To 2
Points(Counter) = StartPoint(Counter)
Next Counter
Points(Counter + 3) = EndPoint(Counter)
Next Counter
'Create the leader object
ThisDrawing.ModelSpace.AddLeader Points, Annotation, LeaderType
Application.Update
On Tue, 17 Dec 2002 13:34:36 -0800, "Nate"
Are you trying to get rid of the little 'flag' line?
__
h \
e \
r \|
e -+
And be left with:
(please pardon the bad art)
