Layers
Layers
Layers
I need to be able to create a routine or reactor that will not allow my ADT
2006 users to create or change any layers. How can this be done. Any help
would be appreciated.
Perhaps something like this would do the trick!
Joe
Option Explicit
Dim lngLayers As Long
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
If UCase(CommandName) = "LAYER" Then lngLayers = ThisDrawing.Layers.Count
End Sub
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
If UCase(CommandName) = "LAYER" And ThisDrawing.Layers.Count > 1 Then
Do While ThisDrawing.Layers.Count <> lngLayers
ThisDrawing.Layers(ThisDrawing.Layers.Count - 1).Delete
Loop
End If
End Sub
"Nate Hunter" wrote in message
news:[email protected]...
I was acutally ahead of you. This is exactly what I did. thanks for the
input
"Joe Sutphin" wrote in message
Joe
Option Explicit
End Sub
Loop
End If
End Sub
Advice: Don't even think about using the code
Joe posted. It can easily erase all the layers
in your drawing.
Suppose for example, the user adds one layer and
deletes two or more others. In that case the number
of layers will never be equal to what it was at the
start of the command and so, Joe's code will just
start deleting all the layers.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Nate Hunter" wrote in message news:[email protected]...
Good catch, didn't think of that ... but you're absolutely right.
Joe
"Tony Tanzillo" wrote in message
in your drawing.
