Launch AutoCAD and Create a Search File Path
' Hi,
' I did the below bit and pieces code to launch AutoCAD from my exe and also
' to create a new Search File Path from where I launched folder, but only
works if I have AutoCAD already opened
' not from scratch (from the exe) it always create the path from:
\windows\system32
' can someone test this is for Visual Basic, thanks Luis E.
Option Explicit
Public objAcad As AcadApplication
Public ThisDrawing As AcadDocument
Sub main()
Dim AcadRunning As Boolean
On Error GoTo Err_Control
AcadRunning = IsAutoCADOpen()
If AcadRunning Then
Set objAcad = GetObject(, "AutoCAD.Application")
Else
Set objAcad = CreateObject("AutoCAD.Application")
End If
' starting code to create the Search File Path
Dim preferences As Object
Set preferences = objAcad.preferences
Dim SPath As String
SPath = preferences.Files.SupportPath
Dim addPath As String
addPath = objAcad.ActiveDocument.GetVariable("DWGPREFIX")
' just testing to show what path is added
MsgBox ("New path: " & addPath)
Dim lengthPath As Integer
lengthPath = Len(addPath)
If Right(addPath, 1) = "\" Then
addPath = Left(addPath, lengthPath - 1)
End If
' add our folder where we have installed our application
' or from where AutoCAD is opened
If StrConv(SPath, 1) Like "*" & addPath & "*" <> True Then
preferences.Files.SupportPath = SPath & ";" & addPath
End If
objAcad.Visible = True
Set ThisDrawing = objAcad.ActiveDocument
Exit_Here:
Exit Sub
Err_Control:
MsgBox Err.Description
Resume Exit_Here
End Sub
Function IsAutoCADOpen() As Boolean
On Error Resume Next
IsAutoCADOpen = (Err.Number = 0)
Set objAcad = Nothing
Err.Clear
End Function
Luis,
Here's your answer.
Joe
'open AutoCAD
If Err Then
Err.Clear
If Err Then
MsgBox "Could not start AutoCAD!", vbCritical, "Error - AutoCAD not found"
'unload application form
Unload Me
'exit the application
Exit Sub
End If
End If
'starting code to create the Search File Path
Dim oPreferences As AcadPreferences
Dim SPath As String
Set oPreferences = objAcad.preferences
SPath = oPreferences.Files.SupportPath
'just testing to show what path is added
End If
'add our folder where we have installed our application
'or from where AutoCAD is opened
End If
'make AutoCAD visible
Scrap the IsAutoCADOpen() function.
Joe
Thank Joe,
But it does the same as my previous code, I will keep testing.
luis
Luis,
It worked prefectly for him so maybe I'm missing something. Perhaps more explanation would help.
Joe
"joesu" wrote in message
news:f14b867.1@WebX.maYIadrTaRb...
Joe
Here is my previous code that I want it to update for AutoCAD 15, can you
tested please (is not working...):
What I want to do is to launch autocad from my exe and create a support path
from where I have my exe.
thank you,
luis
Option Explicit
Option Compare Text
Declare Function RegQueryValueEx& Lib "advapi32.dll" Alias
"RegQueryValueExA" (ByVal hKey&, ByVal lpszValueName$, ByVal lpdwRes&,
lpdwType&, ByVal lpDataBuff$, nSize&)
Declare Function RegOpenKeyEx Lib "advapi32.dll" Alias "RegOpenKeyExA"
(ByVal hKey As Long, ByVal lpSubKey As String, ByVal ulOptions As Long,
ByVal samDesired As Long, phkResult As Long) As Long
Private Function GetAppPath(subkey As String, sAppEntry As String) As String
Dim s As String * 255, sAppPath As String
Dim lAppKey As Long, lType As Long, lLen As Long, lRC As Long
Const HKEY_LOCAL_MACHINE = &H80000002
Const HKEY_CLASSES_ROOT = &H80000001
Const KEY_QUERY_VALUE = &H1&
Const KEY_ENUMERATE_SUB_KEYS = &H8&
Const KEY_NOTIFY = &H10&
Const READ_CONTROL = &H20000
Const STANDARD_RIGHTS_READ = READ_CONTROL
Const KEY_READ = STANDARD_RIGHTS_READ Or KEY_QUERY_VALUE Or
KEY_ENUMERATE_SUB_KEYS Or KEY_NOTIFY
lLen = Len(s)
lRC = RegOpenKeyEx(HKEY_CLASSES_ROOT, sAppEntry, 0, KEY_READ, lAppKey)
If lRC <> 0 Then Exit Function
lRC = RegQueryValueEx(lAppKey, subkey, 0, lType, s, lLen)
GetAppPath = Left$(s, lLen - 1)
End Function
Sub Main()
Dim Acaddir As String
Dim version As String
Dim result As Boolean
Dim sAcadEntry As String
sAcadEntry = "AutoCAD.Drawing.15\shell\open\command"
version = GetAppPath("command", sAcadEntry)
Acaddir = GetAppPath("AcadLocation", sAcadEntry & "\" & version)
If StrConv(Dir(Acaddir & "\ACAD.EXE"), 1) Like "ACAD.EXE" <> True Then
MsgBox ("AutoCAD Ver. 15 not installed. Please refer to User Manual.")
End
End If
result = Shell(Acaddir & "\acad.exe /b myapp.scr", 1)
'Wait 20 second to let AutoCAD open
Dim TimeNow As Double
Dim TimeEnd As Double
TimeNow = Hour(Now()) + (Minute(Now()) / 60#) + (Second(Now()) / 3600#)
TimeEnd = TimeNow + (180# / 3600#)
While TimeNow < TimeEnd And result <> True
3600#)
Wend
If result <> True Then
MsgBox ("Cannot open AutoCAD 15.0")
End
End If
Dim acadApp As Object
Set acadApp = GetObject(, "AutoCAD.Application")
Set preferences = acadApp.preferences.Files
Dim SPath As String
Dim newPath As String
newPath = acadApp.ActiveDocument.GetVariable("DWGPREFIX")
Dim LnewPath As Integer
LnewPath = Len(newPath)
If Right(newPath, 1) = "\" Then
newPath = Left(newPath, LnewPath - 1)
End If
'Add our folder where we are installed our application
If StrConv(SPath, 1) Like "*" & newPath & "*" <> True Then
preferences.Files.SupportPath = SPath & ";" & newPath
End If
Set acadApp = Nothing
Set preferences = Nothing
End Sub
using Luis's first code I am getting an error, that described as "Call was
rejected by callee."
I am working with Acad2002 and VB.NET
Do you have some suggestions?
