Keep API dialog on top (Modal)
fxcastil
Message 1 of 9
fxcastil
I want to keep the API dialog forms such as (Folder & File Search) . I do not want the user to be able to mouse click inside the AutoCAD window when the from is shown, because this will minimize the dialog box and put it in the taskbar. I have read mant posts about how to do this but I can not keep the dialog form on top. The attached file has examples of how I tried to implement the previous posts.
Replies (8)
Message 2 of 9
I use the following in VB executables I run from an ACAD macro:
*** The calling routine
mdlWindow.MakeTopMost Me.hwnd
Me.WindowState = 0
*** In a module I call mdlWindow.bas
Private Declare Function SetWindowPos Lib "user32" _
(ByVal hwnd As Long, _
ByVal hWndInsertAfter As Long, _
ByVal x As Long, y, _
ByVal cx As Long, _
ByVal cy As Long, _
ByVal wFlags As Long) As Long
Private Const HWND_TOPMOST = -1
Private Const HWND_NOTOPMOST = -2
Private Const SWP_NOMOVE = &H2
Private Const SWP_NOSIZE = &H1
Private Const SWP_NOACTIVATE = &H10
Private Const SWP_SHOWWINDOW = &H40
Private Const TOPMOST_FLAGS = SWP_NOMOVE Or SWP_NOSIZE
Public Sub MakeTopMost(Handle As Long)
SetWindowPos Handle, HWND_TOPMOST, 0, 0, 0, 0, TOPMOST_FLAGS
End Sub
Public Sub MakeNormal(Handle As Long)
SetWindowPos Handle, HWND_NOTOPMOST, 0, 0, 0, 0, TOPMOST_FLAGS
End Sub
It will remain stubbornly on top unless you put the minimize button on the
form and click it.
Lennart
wrote in message news:4995221@discussion.autodesk.com...
Message 3 of 9
fxcastil
Lennart,
Can I get you to do me BIG favor and add this code to the file
I attched I had tried what you described in the attached file , but I can not get it working.
Fred C
Message 4 of 9
Fred,
I do not see an attachment 🙂
I use the following...
In a code module:
Public Const SWP_DRAWFRAME = &H20
Public Const SWP_FRAMECHANGED = &H20
Public Const SWP_HIDEWINDOW = &H80
Public Const SWP_NOACTIVATE = &H10
Public Const SWP_NOCOPYBITS = &H100
Public Const SWP_NOMOVE = &H2
Public Const SWP_NOSIZE = &H1
Public Const SWP_NOREDRAW = &H8
Public Const SWP_NOZORDER = &H4
Public Const SWP_SHOWWINDOW = &H40
Public Const FLAGS = SWP_NOMOVE Or SWP_NOSIZE
Public Const HWND_BOTTOM = 1
Public Const HWND_BROADCAST = &HFFFF&
Public Const HWND_DESKTOP = 0
Public Const HWND_NOTOPMOST = -2
Public Const HWND_TOP = 0
Public Const HWND_TOPMOST = -1
' Used for dealing with Forms
Declare Function SetWindowPos Lib "user32" (ByVal hwnd As Long, ByVal hWndInsertAfter As Long, ByVal X As Long, ByVal Y As Long, ByVal cx As Long, ByVal cy As Long, ByVal wFlags As Long) As Long
Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As Any, ByVal lpWindowName As Any) As Long
Public Function SetTopMostWindow(hwnd As Long, TopMost As Boolean) As Long
If TopMost = True Then
SetTopMostWindow = SetWindowPos(hwnd, HWND_TOPMOST, 0, 0, 0, 0, FLAGS)
Else
SetTopMostWindow = SetWindowPos(hwnd, HWND_NOTOPMOST, 0, 0, 0, 0, FLAGS)
End If
End Function
And then in the Form's Initialize Event:
Dim retVal As Long
Dim hwndForm As Long
hwndForm = FindWindow(0&, UserForm1.Caption)
retVal = SetTopMostWindow(hwndForm, True)
Message 5 of 9
His first post had one.
Matt W
"Children are like TV sets. When they start acting weird, whack them across
the head with a big rubber basketball shoe."
Message 6 of 9
Thanks :)...I caught that after re-reading posts...
no editing of posts it seems 😞
Message 7 of 9
fxcastil
cmd,
The example you gave me uses the userform handle as the argument when calling the function for the setting the top most window. The example in my original post is not a VBA useform but an API dialog box. This is where I am having problems I have tried different methods of getting the dialog box handle and then passing this to the topmost function but still no sucess. I would really appreciate if someone could fix the sample file in my original post so I can actually this this implemented . I have tried all the suggestions given to me but I still can not get it right
Fred
Message 8 of 9
fxcastil <> wrote in news:4995987@discussion.autodesk.com:
> cmd,
> Thanks,
> Fred
Setting BrwsInfo.howner = AutoCAD.hwnd should work, At least id did in
WindowsXP and Autocad 2006
- Jose
Message 9 of 9
fxcastil
Jose,
Thanks a bunch that was the trick. Unfortunately not a lot of information on the API function properties is available. I used the function
Declare Function GetActiveWindow Lib "user32" () As Long
to get the active AutoCAD.hwnd , this was an easy fix knowledge is wonderful thing.
Fred C.
