Is there a way to connect the two different worlds(Action Parameter <-> Constraints Parameter)?
hyunmin.park
hyunmin.park
Community Visitor
Community Visitor
I am working on some dynamic blocks for conveyor.
But I got some frustration due to the fact that the constraint parametr cannnot be used for action parameter...)
Can this be possible if I use the VBA?
And one more quesion if VBA works,
Can anyone use the dyn block with VBA codes?
Thank you very much for your replies in advance.
Ed__Jobe
The VBA api does not reference the constraint parameters manager. It only has methods to get a constraint's expression and value. You might ask in the .NET forum.
Ed
How to post your code.
