Is it possable to plot previous using VBA?
muckmailer
muckmailer
AutoCAD 2010, VBA
Thank you,
arcticad
you can do it with lisp
{code}
(defun c:plotp ()
(command "-plot" "no" "" "previous plot" "" "" "" "")
{code}
(defun botsbuildbots() (botsbuildbots))
wbdehaan
Is it possible to start it with VBA?
I do not want to use Lisp, because (when using lisp) when you click spacebar after the macro exits, it will only start the plot-command and not restart the macro.
kind regards,
Wouter de Haan
arcticad
I just discussed that here
http://discussion.autodesk.com/forums/thread.jspa?threadID=770894&tstart=0
