Invalid AutoSavePath
saboh12617
saboh12617
Hello all,
Do you know why, using the AutoCAD LT 2025 Help | AutoSavePath Property (ActiveX) | Autodesk, i can not change it to, for instance my desktop :
To make it clear i am certain the path i give is correct, i tried it for other automations and it works, but when i want to change the autosavepath i am facing an issue: I can change it from
%temp% to %temp%/test/ for instance, but it will run an automation error if i target my desktop, which is in read/write as far as i know.
Working code :
Sub test()
  Dim z As AcadPreferencesFiles
  Set z = Application.Preferences.Files
  Dim x As String
  x = z.AutoSavePath & "test\"
  z.AutoSavePath = x
End Sub
Not working code :
Sub testNotWorking()
  Dim x As String
  x = "C:\Users\XXXX\Desktop\test\"
  z.AutoSavePath = x
End Sub
norman.yuan
I am not sure I know what you mean by "desktop", when you say "...i can not change it to, for instance my desktop", and " if i target my desktop". Where you tried to run the code you posted from? It certainly cannot run INSIDE AutoCAD LT, because Acad LT DOES NOT support running VBA code. Yes, since ACAD LT 2024, it does support AutoCAD ActiveX/COM API INERNALLY, only via Visual LISP. So, the code you showed is useless with AutoCAD LT. If you have to manipulate autosave path, (or other preferences, for that matter), you need to use VisualLisp to access the COM object Application.AcadPreferences.Files.
Norman Yuan
Drive CAD With Code
Ed__Jobe
You pointed to an AutoCAD LT help document. Was that a mistake and you are actually using full AutoCAD, since you said the first code worked? If you can actually run vba, then keep in mind that the backslash is an escape character when passing a string. That means that the character after the backslash has special meaning, e.g. \n means the newline character. Since the backslash and double quote mark have special meaning in programming, preceding them with a backslash passes them as a literal string, e.g. "C:\\Users\\xxxx\\Desktop\\test\\".
Ed
How to post your code.
saboh12617
Oh yes sorry i did put the link to the wrong help page, it is just the first one that showed up on google but i am indeed using full AutoCAD.
@ed i first thought of this as well, but i did not know how to escape the "\" in VBA…
I did some tests and for some reason the problem was due to spaces in the directory path. In the last example "XXXX" was like "Paul Palo" and AutoCAD was throwing an error at me. But using VBA' Space function, it worked.
Ie.
Sub testWorking()
  Dim x As String
  x = "C:\Users\Paul Palo\Desktop\test\"
  ' error here
  z.AutoSavePath = x
  x = "C:\Users\Paul" & Space(1) & "Palo\Desktop\test\"
  ' no error here
  z.AutoSavePath = x
End Sub
I reckon the same behavior as in PowerShell commands, maybe internally there are some differences that i am not aware of.
Anyway problem got solved this way. Thanks for your feedbacks, have a good day.
Ed__Jobe
This is a Windows requirement. All paths that have a space on them must be enclosed in double quotes. As I pointed out last time, you need to escape these too.
"\”C:\\Users\\Paul Palo\\Desktop\\test\\\”".
Ed
