INTERSECT Regions ????????
08:57 PM
- Mute
- Permalink
- Report
Modify menu >> Solids Editing >> Intersect.....I am trying to get Intersection of different regions using VBA. But till now i am not successful. Here is the uncomplete code [[[[[Public Sub OptRegion(ByVal sLayName As String) On Error Resume Next Set OptRgn = ThisDrawing.SelectionSets.Item(sLayName) If Err Then Err.Clear Set OptRgn = ThisDrawing.SelectionSets.Add(sLayName) 'Else 'gsset.Clear 'gsset.Delete End If 'define type of selection set (crossing, window, etc, in this case, all) Dim mode As Integer mode = acSelectionSetAll 'this is a selection set filter Dim gpCode(0) As Integer Dim dataValue(0) As Variant gpCode(0) = 8 dataValue(0) = sLayName 'this is selection set filter data Dim groupCode As Variant, dataCode As Variant groupCode = gpCode dataCode = dataValue 'this collects all objects on 'sLayName' layer into the seletion set OptRgn.Select mode, , , groupCode, dataCode End Sub]]]]]]]]]]]]]]] Thanks in advance Mniaz
