Insertion point for dynamic blocks not matching those shown in properties
Thomas.Long
Thomas.Long
So I wrote a program that updates the UCS, grabs a bunch of dimensions, then writes out a bunch of properties for selected blocks. It then compares the coordinates on the blocks to the dimensions to determine the geometry of the entire assembly. Up until now I haven't had any issues. Most of the time it would update the UCS and write out the information to an excel file exactly as expected.
Recently I had an issue where it got the geometry completely wrong. On further inspection it was because the dimensions were outputting the correct numbers but the blocks were still using the world UCS. Anyone have any idea why the blocks weren't updating their coordinates when I updated the UCS? To be clear I did double check, and the UCS had properly updated to the new point. It looks like the blocks are showing in their properties the new updated ucs system coordinates but when I do a get on the insertion point in VBA it's giving me the coordinates for the world ucs only there.
Function WriteBase(xlApp, xlBook, BeamSheet, StringerSheet)
On Error GoTo ErrorHandler
'Variables for arranging objects by x coordinates
    Dim oArrangedEnt As AcadEntity
    Dim oEnt As AcadEntity
    Dim BeamArray() As AcadBlockReference
    Dim oHolder As AcadBlockReference
    Dim StringerArray() As AcadBlockReference
    Dim oSset As AcadSelectionSet
    Dim oLength As Double
    Dim LastInsertion As Double
    Dim i As Integer
    Dim irow As Integer
    Dim j As Integer
    Dim rowCounter As Integer
    Dim oSize As String
    Dim EndPoint As Variant
    Dim Props As Variant
    Dim StartPoint As Variant
'Intializing Arrays
    ReDim BeamArray(0)
    ReDim StringerArray(0)
'Select Information
    Set oSset = ThisDrawing.PickfirstSelectionSet
    oSset.Clear
    Dim fcode(0) As Integer
    Dim fdata(0) As Variant
    fcode(0) = 0
    fdata(0) = "INSERT"
    oSset.SelectOnScreen fcode, fdata
'Separate beams and stringers into different arrays
    For Each oEnt In oSset
        If oEnt.IsDynamicBlock Then
            Props = oEnt.GetDynamicBlockProperties
            For i = LBound(Props) To UBound(Props)
                If Props(i).PropertyName = "Visibility1" Then oSize = Props(i).Value
            Next
            StartPoint = oSize & "StartPosition"
            EndPoint = oSize & "EndPosition"
            oEnt.GetBoundingBox StartPoint, EndPoint
            If StartPoint(0) - EndPoint(0) > StartPoint(1) - EndPoint(1) Then
                Set BeamArray(UBound(BeamArray)) = oEnt
                ReDim Preserve BeamArray(UBound(BeamArray) + 1)
            Else
                Set StringerArray(UBound(StringerArray)) = oEnt
                ReDim Preserve StringerArray(UBound(StringerArray) + 1)
    Next
    ReDim Preserve StringerArray(UBound(StringerArray) - 1)
    ReDim Preserve BeamArray(UBound(BeamArray) - 1)
'Sorting beam and stringer arrays by x and y dimensions respectively
    For i = LBound(BeamArray) To UBound(BeamArray) - 1
        For j = i + 1 To UBound(BeamArray)
            If BeamArray(i).InsertionPoint(0) > BeamArray(j).InsertionPoint(0) Then
                Set oHolder = BeamArray(j)
                Set BeamArray(j) = BeamArray(i)
                Set BeamArray(i) = oHolder
        Next
    Next
    For i = LBound(StringerArray) To UBound(StringerArray) - 1
        For j = i + 1 To UBound(StringerArray)
            If StringerArray(i).InsertionPoint(1) > StringerArray(j).InsertionPoint(1) Then
                Set oHolder = StringerArray(j)
                Set StringerArray(j) = StringerArray(i)
                Set StringerArray(i) = oHolder
        Next
    Next
'Declaring excel sheet formatting
    With BeamSheet
        .Range("A:A").NumberFormat = "0.00#"
    End With
    With StringerSheet
        .Range("D:D").NumberFormat = "0.00#"
        .Range("E:E").NumberFormat = "0.00#"
    End With
'Write beams and stringers into excel sheet
    With BeamSheet
        For irow = 1 To UBound(BeamArray) + 1
            Props = BeamArray(irow - 1).GetDynamicBlockProperties
                    .Cells(irow, 2) = Props(i).Value
            Next
            If .Cells(irow, 1) > BeamArray(irow - 1).InsertionPoint(0) Then
                .Cells(irow, 3) = "Left"
            Else
                .Cells(irow, 3) = "Right"
        Next
    End With
    With StringerSheet
        LastInsertion = 0
        For irow = 1 To UBound(StringerArray) + 1
            rowCounter = irow
            If 0.005 > StringerArray(irow - 1).InsertionPoint(1) - LastInsertion Then
                Do While .Cells(rowCounter, 1) <> ""
                    rowCounter = rowCounter + 1
                Loop
                For i = rowCounter To irow Step -1
                    .Cells(i, 1) = .Cells(i - 1, 1)
                Next
            LastInsertion = StringerArray(irow - 1).InsertionPoint(1)
            Props = StringerArray(irow - 1).GetDynamicBlockProperties
                If Props(i).PropertyName = oSize & "_Length" Then oLength = Props(i).Value
            Next
            StringerArray(irow - 1).GetBoundingBox StartPoint, EndPoint
            .Cells(irow, 4) = StringerArray(irow - 1).InsertionPoint(0)
            If .Cells(irow, 1) < StringerArray(irow - 1).InsertionPoint(1) Then
                .Cells(irow, 3) = "Side C"
            Else
                .Cells(irow, 3) = "Side A"
            If EndPoint(0) < StartPoint(0) Then
                .Cells(irow, 5) = StringerArray(irow - 1).InsertionPoint(0) - oLength
            Else
                .Cells(irow, 5) = StringerArray(irow - 1).InsertionPoint(0) + oLength
        Next
    End With
'Error Handler
ErrorHandler:
    If Err.Number = -2147352567 Then
        Call ErrorHandler(xlApp, xlBook, BeamSheet, StringerSheet)
        Exit Function
End Function
'Saves and Exits Excel
Function ErrorHandler(xlApp, xlBook, BeamSheet, StringerSheet)
        xlApp.Save
        xlApp.Quit
        Set BeamSheet = Nothing
        Set StringerSheet = Nothing
        Set xlBook = Nothing
        Set xlApp = Nothing
End Function
Thomas.Long
Apologies, upon further inspection I found that the insertionpoint property of a block was always based upon the UCS. I have amended my code with the TranslateCoordinates method in order to account for this error and it works properly now.
