Inserting Blocks Using Delphi - Tony?
I've used Delphi extensively (thanks to Tony T.) and up to this point have
not had the need to insert a block. I'm using AutoCAD r14.01. I don' t
want to insert a drawing file since I like my applications to be self
sufficient when possible. I'm actually checking the block table to see if
it exists, if not the block is created. Up to this point everything works
great. I've checked to see that the block definition was created and was
able to insert the block using the insert command.
Where I run into problems is when I call the InsertBlock() method. I don't
get an error but the block is not inserted and there is a message displayed
everytime the method is called "Invalid Complex Object" or something to that
effect.
I don't have the code with me but after having creating a successful block
definition I call the following:
var
pt1 : OleVariant;
Hugo,
Do you really want to insert your block in another one
(nested block). In this case you won't see it immediately
unless the BlockEnt is referenced to *ModelSpace or
*PaperSpace. Naturally you cannot insert a block in
its own definition. I haven't checked this but it may result
in an "Invalid Complex Block".
If you just need to insert your block in ModelSpace try to
replace your BlockEnt with the ModelSpace object.
Denis
Hugo Guerrero a écrit dans le message
<82ak09$8p92@adesknews2.autodesk.com>...
>Hi,
that
>effect.
>var
>pt1 : OleVariant;
>begin
>pt1 := AcPoint(1,1,0);
>BlockRef := BlockEnt.InsertBlock(pt1,'PT',1,1,0);
>end;
>Any help is appreciated.
>Hugo
Hugo - I can't guess what's going on in your code.
If you can post it, I'll have a look.
Hugo Guerrero wrote:
> Hi,
> effect.
> var
> pt1 : OleVariant;
> begin
> end;
> Hugo
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
