I want to remove the vba macro from the dwg file using accoreconsole.exe
I would like to know how to remove the vba macro from the dwg file. Is there anyone you can help me with? ..
Please Help!
Ed__Jobe
Type VBAMAN at the command prompt to run the vba manager. At the top of the dialog, it will show the embedded vba projects. Select one and then click on the EXTRACT button.
Ed
How to post your code.
Thank You!!!
