I get an error trying to call AutoCAD 2011 from Visual Basic
I get an error trying to call AutoCAD 2011 from Visual Basic. I am not an expert in programming so im trying to find out how to call AutoCAD 2011 from VB.
Private Sub Next_Click(ByVal sender As System.Object, ByVal e As System.EventArgs)Handles Next.Click
Dim ACAD As Autodesk.AutoCAD.Interop.AcadApplication
ACAD = CreateObject("autocad.Application.18")
ACAD.ActiveDocument.SaveAs("new")
ACAD.ActiveDocument.Save()
ACAD.ActiveDocument.Close()
end sub
but everytime i get to the third line, i get an activeX error.
i am really stuck here because i've tryied everything i know and everything i've found on the internet.
thank you
I haven't written any VBA code in ACAD since version 2006, but if you can give me some more info, I will try to help.
A couple of questions:
What exactly is the end purpose of the sub you are trying to create?
Are you writing the VBA code to reside within an AutoCAD file using the VBA editor in AutoCAD, with VBA in another application, such as Excel, or as a standalone ap created in VB Studio?
pendean
Community Legend
Community Legend
I believe you need to "Set" an object to instanciate it.
Set ACAD = CreateObject("autocad.Application.18")
Mike.Wohletz
try changing this line:
to this:
ACAD = CreateObject("autocad.Application.18.1")
AutoCAD 2011 is version 18.1 and while the first will work if the machine has never had another version of AutoCAD installed. If it has had another version installed it will fail because now you must grab the correct version.
Yes. I also have the same problem. I had cheanged
to
But it still can not work when the first run. At the second time, it mybe sometime OK and sometime failed
