I CAN'T USE GROUP(NAME's) IN VBA
I'm using group's a lot in my daily practice.
So why not in VBA I thougt.
Creating a group and adding some objects to seams no problem.
But using the group in some common commands is a problem. I always get the
error that the name
of the group doesn't exist. Opening the dialogue-box the group created in
VBA is listed.
What can be the problem.
Thanks for your reply.
JO
jo had this to say:
> get the error that the name
> created in VBA is listed.
Can you be more specific? Are you executing these commands at the command
line or programmatically?
"If you want to be somebody else change your mind"
http://www.acadx.com
I have the same problem as you.
and I'm trying my best to get some help,I u find it out now, could you reply here.
and the problem is described as below:
I created group use vba code, and when I use group name interactively with AutoCAD, it cannot be used.
but if i created group interactively with AutoCAD(not in vba), there is no problem, why this happen.
