I would like to "...see an ActiveX control that represents just the file structure of a ... " PLT file and draws it on image/picture. I need a lawyer here... :)
similar to "HatchPattern.ocx", "DwgThumbnail.ocx" where some method, say, .FileName, can be pointed to a file and be loaded in sizable image. I don't want to go in to whish-list details about properties and methods.
To manipulate PLT file structure by modifying the code will be little far from my request at this time. I know that there are some applications in the market they do so. Repro-desk is one of them and I don't like it because it never got upgrade from my grandfather's engagement era and it does not allow printing in-house using different media sizes. Other PLT viewers (99.99% shareware) are overwhelmingly too match what architectural midsize businesses need; and there are not cheap. In addition to this and some other concerns I'm thinking, would be grate if Autodesk will provide some kind of utility to play with PLT files, view, pan, modify etc.
My initial question was is there available FREE "programming tool, Component, ActiveX" (I need some lawyer here) available in the market to do what I try to do with PLT files (view at least).
"Ed Jobe" wrote in message news:41adf5fa$1_2@newsprd01...
Thank you for your observations, guys. but, while you both are technically correct, I wasn't trying to provide a definition of ActiveX, just an analogy that was applicable to this case since he didn't understand my request for clarification of his purpose. He didn't ask for a control to "handle" or "access" hpgl files. In fact he didn't specify anything that he wanted to do. What if he wants something to translate hpgl files? If he had been more specific about what he wanted, both/either of you should have provided him with it. At least your additional comments are there for others to read.
However, What I said is not really at odds with you either. I was speaking from a point of view of general practice, not theory. Your definition said, "can be used", whereas I was talking about what is used in a specific case. Generally, you won't see an ActiveX control that represents just the file structure of a dwg, or xls or doc (admittedly I'm stating this without doing an exhaustive search). But you *might* find something that *manipulates* the file in some way. What I was trying to draw out of him is, what manner he desired to manipulate an hpgl file. Without that, all I can tell him is "go Google it".
Ed
"Jorge Jimenez" wrote in message news:41ad6df1$1_3@newsprd01...
Ed, you seem to have the wrong definition for ActiveX
There are many ways to define ActiveX but this one
is simple and clear:
"A programming methodology that was developed
by Microsoft and can be used to isolate
software components and build functions
using those components"
So there is nothing wrong in asking for an ActiveX control
to handle HPGL files.
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
"Ed Jobe" wrote in message news:41acd3f4_2@newsprd01...
> Its obvious you need it for programming, but what task do you need to
> accomplish.
> ActiveX is for objects, whereas, hpgl is a specification for a file type.
> Its like asking for an ActiveX for dwg when you need it for Autocad, the
> object that manipulates the dwg file.
> Since you are asking the wrong question, it would help us if you explained
> what you are trying to do.
> Ed
> "TAPXYH" wrote in message news:41acc76f$1_3@newsprd01...
>> Just kidding.
>> I need that for my VB programming...
>> news:41ac9ac8$1_2@newsprd01...
>> > What are you trying to do?
>> > Ed
> news:41ac494b_2@newsprd01...
>> > > Is there any free HPGL/HPGL2 ActiveX component for VB/VBA programmers?
